Previous in Forum: Transformer Oil Maintenance   Next in Forum: Oil and gas electrical inspector training
9 comments
Vacuum interrupter in GIS
02/22/2022 12:44 AM
Dear sirs,
Can somebody please tell me where is 'medium voltage interrupters with gis is used'. What are its advantages for its application in generator circuit breaker?
regard
Anonymous Poster #2
Re: Vacuum interrupter in GIS.
02/22/2022 3:07 AM
Loads of people can. Try this.
02/22/2022 7:18 AM
<...What are its advantages for its application in generator circuit breaker?...>
Compared to what else?
02/22/2022 9:45 PM
02/23/2022 12:33 AM
There is little to no advantage other than size for a generator circuit breaker. They are much more useful in applications with significant numbers of operations per day. Surge arresters are used to reduce voltage excursions that come with the sharp interruption of current typically associated with vacuum interrupters. Air break equipment provides a softer interruption that applies less stress to the stator winding insulation. Air break equipment is also a lower technical level for maintenance & repair, which sometimes is an advantage for the owning facility.
02/23/2022 4:22 AM
do u mean to say that gis with vacuum interrupters are more useful in generators with more number of interruptions per day? In my thinking, number of generator operations per day can not be guaranteed...is there any specific case where number of generator interruptions will be more? In a bad day with system collapse, there may be more no of vacuum interrupters per day while on some good days, there may not be any.
02/23/2022 6:54 AM
Is this a front-end design problem or a standardisation one?
Is there no established procedure within the facility for doing this?
02/23/2022 10:55 AM
I would not expect a medium voltage generator breaker to operate more than once a month, maybe less. Also, the stress on the interruption mechanism is much lower on a generator application than for an induction motor. If it was mine, I’d want to have a really good reason to apply a vacuum interrupter, because they are a risk to the machine insulation system.
You did not take that away from my first comment?
Location: 3rd rock from the sun,a small dust mote,in a small insignificant spiral galaxy referred to locally as the Milky Way
02/27/2022 8:51 AM
In mission critical operations, always design for the worst case scenario.
There is no darkness except for ignorance..Shakespeare
02/24/2022 7:01 AM
Is there no applicable and appropriate electrical standard locally that can be consulted?
Anonymous Poster (2); hitekrednek2 (1); PWSlack (3); rwilliams (2); SolarEagle (1)
