Previous in Forum: Center of gravity too high   Next in Forum: How do I get back into receiving regular contact
Location: 3rd rock from the sun,a small dust mote,in a small insignificant spiral galaxy referred to locally as the Milky Way
Adhesive used for disc brake pads?
03/06/2022 9:38 PM
What type of adhesive is used to bond disc brake pads to the metal backing?
There is no darkness except for ignorance..Shakespeare
Re: Adhesive used for disc brake pads?
03/07/2022 12:53 AM
03/07/2022 9:23 PM
What is really amazing is this stuff stands up to the heat. Many adhesives lose a lot of strength as the temps go up.
03/08/2022 2:45 AM
Not to mention moisture and chemical resistance...tough stuff
03/08/2022 9:02 PM
I don't know how SE finds this stuff. But the adhesive they use here is really amazing...
After SE posted, I looked this up... I only could only find how its applicated. And after the Columbia, they had a way to repair in space... how they fit the blocks they didn't say.
03/08/2022 10:20 PM
Back in the '70's a repair shop had a set of stones,shaped like disc pads that were used to remove minor grooving on disc pads.The stones were bonded to a pad's metal backing.
They were installed in place of the pads,and the car was driven slowly,and the brakes were applied gently.
After a couple of times around the shop,the discs were inspected,and most had a perfectly smooth finish.
The stones looked like a coarse grit emery.
I was inquiring to see if it may be possible to make a set for my own use.
Now I can do it.
Thanks for all the feedback!
03/10/2022 9:26 AM
Please let us know the results when you get your tests done.
Register to Reply 6 comments
Brave Sir Robin (1); hitekrednek2 (1); phoenix911 (1); SolarEagle (2); Trees4Life (1)
