Previous in Forum: Is This the Next Motorcycle   Next in Forum: What is this?
13 comments
Good Answers: 145
Solar Flares
04/01/2022 8:21 AM
We have been having quite a few solar flares in the past couple of weeks. Until recently I never knew how much they actually affected me. And, I now have more of a "first hand understanding" of how they could have a major impact of all of us electricity users.
This report and many others provide information on solar flares, coronal mass ejections (CMEs), sunspots, solar storms and the aurora.
All of my life I have been listening to distant radio stations. It's not normally intentional, it just works out that classic rock is always played somewhere else. Both of the stations I now listen to are far enough away that I am only half joking when I say I can listen to them if I leave home and turn left but not if I leave home and turn right.
Over the past year I have noticed that there is a very high correlation between not being able to listen to my stations and reports of solar flares. Sometimes the listening problems are other stations (usually Miami) "skipping" in on top of my station. Sometime my stations seem to fade in and fade out. It is rare but a couple of times there was just a large amount of static and "crashes" where my station should have been. (Both stations are FM so traditional thunderstorm noise is not an issue).
There is no doubt in my mind that solar weather is why I sometimes get noise instead of rock and roll (no negative "rock is noise" comments needed).
If you use a FM radio (probably in you car) and notice station problems then you might think about this. Also, if you notice it and have children you might consider it a good opportunity to have a "science minute". A little bit of "real world science" can have a huge effect on a young mind.
Pathfinder Tags: cme solar flares
Good Answers: 145
Re: Solar Flares
04/01/2022 10:11 AM
I should have made this posting a few days ago when it was bad. Radio reception was very good this morning.
Re: Solar Flares
04/01/2022 12:22 PM
"Effect of solar flares: For most solar flares, the main effect felt on Earth is an increase in the level of solar radiation. This radiation covers the whole electromagnetic spectrum and elements such as the ultra-violet, X-rays and the like will affect the levels of ionisation in the ionosphere and hence it has an effect on radio communications via the ionosphere. Often an enhancement in ionospheric HF propagation is noticed as the higher layers of the ionosphere have increased levels of iononisation. However if the levels of ionisation in the lower levels start to rise then this can result in higher levels of attenuation of the radio communications signals and poor conditions may be experienced. Additionally an increase in the level of background noise at VHF can also be detected easily."
https://www.electronics-notes.com/articles/antennas-propagation/ionospheric/solar-flares.php
FM radio is in the same frequency band as VHF. A strong FM signal is immune to static. A certain minimum signal to noise (SNR) is necessary for the receiver to lock into an FM signal.
Good Answers: 145
Re: Solar Flares
04/02/2022 10:00 PM
I have always lived where the music I liked best was always a relative weak signal. Therefore, the FM signals have relative static immunity compared to AM signals but they would not be considered to be "immune" from static.
I do know about skip. Back in my ham radio days the skip at night allowed ham contacts, Voice of America, Radio Moscow, various international stations and that annoying Russian Woodpecker to come in. In a previous life I would watch the scope as skip would creep in and threaten or disrupt our lock onto LORAN-C signals.
When I hear "solid" Miami or "bits and pieces of Miami" and it shouldn't be there then that is skip. When I hear nothing but soft static on multiple frequencies where my weak stations should be I am without a strong opinion on what is happening. When I hear multiple and frequent bursts of loud and random noise on top of a signal that is strong enough to receive then I have a strong lean toward either the direct flare burst or CME. It is pretty rare that this happens and there always seems to be a corresponding news report of flares and CME. (no thunderstorms, yes weak FM)
Good Answers: 27
Re: Solar Flares
04/03/2022 9:50 AM
Very strong solar activities not only affects the ionospheric conditions which interferes with the skywave propagation but also the ground conditions as utilized by groundwave propagated signals. Which together in my view will have a net effect on both wanted and unwanted signals, like noises and statics alike, together with the inherent electronic noises within the receiver itself...
vsar
Re: Solar Flares
04/01/2022 5:13 PM
Its interesting, even though I first heard about this with this post, I looked into it a bit.
Here's a little information about the satellites handling this situation.
Good Answers: 27
Re: Solar Flares
04/02/2022 8:07 AM
It is the ionization levels of the D, E, F ionosphere layers that actually makes it possible for the radio signals to reach farther distance from where they are being transmitted.. The RF signals that are refracted and being bounced back to earth at great distance known as "skip distance"..
Skip distance that mostly rely on the ionization levels of the sky, which increases and moves farther up creating several layers in the E and F region of the ionosphere, mainly due to the sun's activities like the so called "CME" coronal mass ejections..
vsar
Re: Solar Flares
04/02/2022 2:41 PM
Re: Solar Flares
04/02/2022 6:50 PM
I wonder if this is why the fire department frequencies on my scanner are getting more static recently? Frequencies 453.3375, 460.575, and 453.6625 are the ones I get, because I don't have a MARCS scanner (yet.)
Lehman57
Location: 3rd rock from the sun,a small dust mote,in a small insignificant spiral galaxy referred to locally as the Milky Way
Re: Solar Flares
04/04/2022 7:43 AM
A bit off topic,but on the old NTSC tv's (analog) when "snow" appears on the screen due to an off-channel tuning(Yes,they had manual tuning in those days of yesteryear), the "snow" is actually the radiation left over from the Big Bang?
Dad(HTRN) said that NTSC stood for Never The Same Color twice.There were individual adjustments for horizontal freq.,vertical, tint,color,contrast,brightness.Eventually they figured out how to eliminate these adjustments.In Russia,they used a different broadcast system.All adjustments were eliminated.Even the on-off button was eliminated.You only watched tv when they allowed it.
There is no darkness except for ignorance..Shakespeare
Re: Solar Flares
04/04/2022 8:23 AM
Yes, I recall that… we also had a multi tool for not only adjust and fine tune it… but it changes the channel also…
Not to mention, that if the wind picked up… one of our siblings had to go out and adjust the antenna to point in the right direction,…
usually, the youngest.
Re: Solar Flares
04/04/2022 8:39 AM
If the channel knob broke,an oven control knob would work.250 degrees for channel 6, 450 degrees for channel 8,etc.
Use it up,fix it up,wear it out.Nothing was thrown away,although I guess some of my dad's 4 track and 8 track cartridges may be obsolete,or soon to be collector items.
Re: Solar Flares
04/04/2022 9:03 AM
now you tell me... unfortunately, the multi-tool now needs to be applied to the oven.
Good Answers: 145
Re: Solar Flares
04/06/2022 6:44 AM
To get the letters right it was "Never Twice the Same Color".
Register to Reply 13 comments
Anonymous Poster (1); BruceFlorida (3); hitekrednek2 (2); Lehman57 (1); phoenix911 (3); Rixter (1); vsar (2)
