Previous in Forum: Solar Flares   Next in Forum: Dual motion transmission for a small project
14 comments
What is this?
04/08/2022 6:20 AM
I found these in an old workshop , who can identify what they are ?
Re: What is this ?
04/08/2022 6:40 AM
Good Morning,
They look like bore cleaning devices to me. Maybe for the barrel of a pistol.
Re: What is this ?
04/08/2022 7:17 AM
They are made from stainless steel , if they were used to clean a gun barrel they would damage the polish in the bore and the rifling.
Re: What is this ?
04/08/2022 7:24 AM
It looks as if the twists are flexible, and would elongate when inserted into the bore, taking its shape and size. This would exert minimal pressure on the bore and clean any residue. Maybe not for a gun barrel, but some kind of bore for sure.
Are the individual strands sharp? Maybe it is a bore maker or enlarger or smoother?
Re: What is this ?
04/08/2022 7:43 AM
if fabric were wrapped around the device , they could be used for cleaning different types of hollow bore.
the exterior is smooth.
Re: What is this ?
04/08/2022 11:28 AM
It's a flex-shaft drive for an RC boat ....
Re: What is this ?
04/08/2022 3:25 PM
...or it could be a buffing accessory for a tubing cleaner...
Good Answers: 119
Re: What is this ?
04/08/2022 11:07 PM
I was gonna suggest tubing cleaners, especially copper, but looks like that's been pretty much covered. Likely powered with a drill motor.
Re: What is this ?
04/08/2022 11:20 PM
I think cleaners for automotive valve guides. Was it an auto repair shop?
Lehman57
Re: What is this ?
04/08/2022 11:25 PM
No
It may have been a general engineer that did everything
Re: What is this ?
04/09/2022 12:26 AM
I agree. Valve guide cleaner/burnishers. I used them back in 1975 rebuilding cylinder heads.
Re: What is this ?
04/09/2022 6:17 AM
Just to give an idea of dimensions: that's an Ausy. 50 cent piece which is about 32mm across
Re: What is this ?
04/09/2022 6:39 AM
the diameters were around 3/8' , 1/2" and 5/8" Gynaecological uses have been ruled out after some consultation with my dear (frightened) lady.
Re: What is this ?
04/09/2022 2:35 PM
It looks like there might be ball bearings inside the wire portion...? This would allow for some adjustability in diameter....maybe
Re: What is this?
04/17/2022 3:32 PM
would guess they are used to lap inside diameters. It looks like if it were rotated clockwise with an electric drill, the diameter would reduce and the opposite would be true if run counterclockwise.
Mr.Ron from South Ms.
Register to Reply 14 comments
Hooker (1); Lehman57 (1); Mfmatusky (1); Nothing is Impossible (4); Randall (1); ronseto (1); schueydoo (2); SolarEagle (3)
