Previous in Forum: Dual motion transmission for a small project   Next in Forum: The Problem With EV Charging Units
Are coronal loops on the sun an optical illusion?
04/08/2022 12:51 PM
"Some of the most spectacular features on the Sun are its coronal loops — incandescent structures of hot plasma that arc for thousands of miles above magnetically active regions of the Sun, forming what appear to be curving strands.
But appearances can be deceiving. Now, a team of solar physicists say these iconic structures may not actually be loops at all. Instead, the loops may be an illusion rooted in a more complex structure — a magnetic sheet or curtain that is being pulled and wrinkled. The team call this the coronal veil, and they think that bright coronal loops appear where the veil is wrinkled and our line of sight runs through more of it."
more...
The Sun’s coronal loops may be an optical illusion _ Astronomy.com
https://iopscience.iop.org/article/10.3847/1538-4357/ac3df9
So, are the coronal loops streams of charged particles, or are they a surface seen edge-on?
Re: Are coronal loops on the sun an optical illusion?
04/08/2022 2:39 PM
Me no think so Kimosabe...
04/09/2022 12:13 AM
Me neither.
04/09/2022 10:58 AM
I've looked at the pictures and I can't see it as a surface either. A telescope located at either L4 or L5 looking at a different angle would settle the question, I would think.
Coronal loops have been studied for quite a while and are still not well understood.
"Coronal heating problem[edit]
For broader coverage of this topic, see Stellar corona § Coronal heating problem. Unsolved problem in physics:
Why is the Sun's Corona so much hotter than the Sun's surface?
(more unsolved problems in physics)
A closed loop of magnetic field, a flux tube above the solar surface, does not by itself constitute a coronal loop; it must be filled with plasma before it can be called a coronal loop. With this in mind, it becomes clear that coronal loops are a rarity on the solar surface, as the majority of closed-flux structures are empty. This means the mechanism that heats the corona and injects chromospheric plasma into the closed magnetic flux is highly localised.[7] The mechanism behind plasma filling, dynamic flows and coronal heating remains a mystery. The mechanism(s) must be stable enough to continue to feed the corona with chromospheric plasma and powerful enough to accelerate and therefore heat the plasma from 6000 K to well over 1 MK over the short distance from the chromosphere and transition region to the corona. This is the very reason coronal loops are targeted for intense study. They are anchored to the photosphere, are fed by chromospheric plasma, protrude into the transition region and exist at coronal temperatures after undergoing intensive heating.
The idea that the coronal heating problem is solely down to some coronal heating mechanism is misleading. Firstly, the plasma filling over-dense loops is drained directly from the chromosphere. There is no coronal mechanism known that can compress coronal plasma and feed it into coronal loops at coronal altitudes. Secondly, observations of coronal upflows point to a chromospheric source of plasma. The plasma is therefore chromospheric in origin; there must be consideration of this when looking into coronal heating mechanisms. This is a chromospheric energization and coronal heating phenomenon possibly linked through a common mechanism."
https://en.wikipedia.org/wiki/Coronal_loop
04/09/2022 12:54 PM
04/10/2022 9:49 AM
https://www.cnet.com/science/space/the-suns-puzzling-heating-problem-is-closer-to-being-solved/
“Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth.” - Sherlock Homes”
Sherlock missed something. Maybe two things that are impossible explanations because neither accounts for all of the evidence, together can account for all of the evidence.
04/09/2022 2:16 PM
If we add gravity into the equation, along with the instability of the field under these conditions, then it seems to me the coronal patterns emerge...
04/10/2022 11:05 AM
The European Space Agency's Solar Orbiter will get an even better perspective on these coronal loops than a telescope at either L4 or L5. The data from this orbiter is new. It will take time to validate and cross-reference with terrestrial observations. I suspect the theoretical papers the OP initially cited were published deliberately prior to the orbiter's data being released so the theory would be "untouched" by observed data.
Register to Reply 7 comments
redfred (1); Rixter (2); SolarEagle (2); StandardsGuy (2)
