Previous in Forum: Teapot terminology   Next in Forum: Using large bore well to improve heat pump efficiency
10,000 times faster than living synapses
08/03/2022 8:24 AM
Researchers are developing analog synapses that can react 10000 time faster than a biological one,and do it very efficiently,using CMOS compatible programmable resistors.
Will this be the next stage of AI development?
Wii humans stand a chance against such computing power?
Info in this link:
https://www.science.org/doi/10.1126/science.abp8064
Re: 10000 times faster than living synapses
08/03/2022 8:38 AM
How does this compare to digital…
Good Answers: 88
Re: 10,000 times faster than living synapses
08/04/2022 11:56 AM
CMOS, i.e. complementary, both N and P mosfets on the same, usally Silicon substrate, is known to have a linear(ish) region of operation which is a disaster on digital systems but can be used as an analog amp, the base for analog computing. Fets are essentially resistors controlled by voltage. But behavior is heavily temp dependant unless negative feedback is applied, so it will be a big headache to compensate for that. Plus ther's significant changes as semiconductors age, can't see how such a system can become reliable with current technology. And ther'll be nothing worse than an analog AI unit with dementia, mood changes and/or multiple personalities.. Well, this can work on humans for a while, you can pass "notes" occasionally to chaps in office, but how can you do that on chips? S.M.
08/08/2022 9:01 AM
The key is to have the AI on our side, and not against us. They are tools for our use, but if they become sentient all bets are off.
08/12/2022 6:40 AM
No worries..Artificial Intelligence will never overcome natural stupidity.
Register to Reply 4 comments
HiTekRedNek (1); phoenix911 (1); SimpleMind (1); StandardsGuy (1)
