Previous in Forum: Digitization in electrical system   Next in Forum: Transformer connection
Hi-Pot Testing in PCB circuit with MOV connected to gnd
08/08/2022 2:48 AM
In a PCB circuit of EV charger / rectifier, containing MOV and GDT from phase to ground, can hi-pot be performed without disconnecting the MOVs?
Will the MOV see the Hi-pot voltage as a transient noise and supress the Hipot test voltage? or is there some other ways of performing Hi-Pot on the PCB
Re: Hi-Pot Testing in PCB circuit with MOV connected to gnd
08/08/2022 7:57 AM
Most likely. You should contact the manufacturer.
08/08/2022 9:02 AM
Of course, one can perform a Hi-Pot test with MOV (Metal Oxide Varistor) and GDT (Gas Discharge Tube) attached. One can perform all sorts of useful, useless, and even damaging tests with a circuit board. Knowing the MOV and GDT will protect the circuit board would undoubtedly be helpful. Performing a Hi-Pot test without the high voltage protection devices attached should prove that the circuit board needs high voltage protection. It all depends on what you wish to be testing.
If you do a Hi-Pot test with the high voltage protection missing then you shouldn't sell that circuit board regardless of the result.
Good Answers: 88
08/08/2022 10:21 AM
Why are MOVs connected to ground? Unless they're there to trip a fuse on lightning etc. If so they're rated just below bulk capacitors' max permitted voltage and of course located before main rectifier. So they are low voltage and no HiPot test to ground possible. Test voltage will latch to MOV voltage and results will be irelevant. It could very well be on specs for HiPot test after the internal fuse, with it being temporarily removed. Or HiPot is only applicable to output. S.M.
Good Answers: 145
08/09/2022 6:50 AM
From my experience:
HI POT TEST GOAL: Expose insulated items (wires, etc) to a high voltage for a specified length of time and expect (for safety) that leakage will be very, very small (possibly zero on your instruments).
MOV GOAL: Pass (kind of like "leak") current when exposed to high voltage. This typically shunts current (high voltage) to ground to protect circuits.
Think about it. We don't know what standards, test procedures, contract requirements, etc. you are dealing with. But, if you agree with the two goals I stated above then you agree that you don't Hi-Pot test a MOV circuit. How do you deal wth this conflict? Well, welcome to Engineering!
08/12/2022 6:28 PM
The best thing to do is to pick up the phone to the manufacturer of the <...PCB circuit of EV charger / rectifier, containing MOV and GDT...> and ask its technical helpline.
Why is this test being carried out if the procedure and the pass criterion is not known about beforehand?
BruceFlorida (1); PWSlack (1); redfred (1); Rixter (1); SimpleMind (1)
