Previous in Forum: Solar generators power system?   Next in Forum: Dead End Poles and Double Dead End Poles
12 comments
PV generator
09/02/2022 5:48 PM
how does it work PV generator, specially how to control the voltage? does it have excitation circuit like other generators?
Re: PV generator
09/02/2022 7:05 PM
I think the term you want to search for is solar inverter.
You can start your quest here:
https://solarmagazine.com/solar-inverters/
There are probably many other sites you can visit as well, but don't go to Camelot. 'Tis a silly place.
Re: PV generator
09/05/2022 5:22 AM
I went to camel lot one time,and all I saw were camels.
You need to check your spelling.
Re: PV generator
09/06/2022 11:04 PM
Funny, the spell checking nanny didn't underline it for me.
I came here for an argument.
Re: PV generator
09/02/2022 11:17 PM
..."A photovoltaic (PV) generator is internally a power-limited nonlinear current source having both constant-current- and constant-voltage-like properties depending on the operating point."Jul 5, 2022"
https://www.researchgate.net/publication/259463468_Photovoltaic_Generator_as_an_Input_Source_for_Power_Electronic_Converters#:~:text=A%20photovoltaic%20(PV)%20generator%20is,depending%20on%20the%20operating%20point.
Re: PV generator
09/03/2022 12:08 AM
Re: PV generator
09/03/2022 2:37 PM
The PV generator is technically not a generator but an inverter, an electronic device that converts direct current from the solar cell array to alternating current that can be used to power AC devices. There is no "exciter".
Re: PV generator
09/03/2022 4:55 PM
Re: PV generator
09/04/2022 9:44 AM
The PV generator voltage is controlled by the amount of SL striking the surface, and the number of PCs in the circuit. The voltage is also highly dependent on the actual LC, so there really is no VC for your SI, analogous to your RM example.
Re: PV generator
09/04/2022 11:11 AM
LMAO RW!
Reply Off Topic (Score 4)
Re: PV generator
09/05/2022 11:38 AM
John: 11, 35.
Re: PV generator
09/05/2022 11:44 AM
Even funnier!
Re: PV generator
09/07/2022 11:02 AM
When I went to a camel lot it was very crowded. I saw 4 times as many camel toes as camels.
Brave Sir Robin (2); Deefburger (1); HiTekRedNek (2); PWSlack (1); Rixter (1); rwilliams (2); SolarEagle (3)
