Previous in Forum: Test bed for rowing machine   Next in Forum: Common Performance Indicators of Autonomous Robots
DG SET OIL LEAKING IN TURBOCHARGER
11/08/2022 11:51 PM
Can anyone suggest reason for oil leak drop by drop from the joint gasket of turbocharger and exhaust turbine of a Cummins DG.
This leak is not there when ran on no load and observed only when DG is loaded to50% and above.
Thank you.
DHAYANANDHAN.S
DHAYANANDHAN.S
Re: DG SET OIL LEAKING IN TURBOCHARGER
11/09/2022 2:45 AM
Sounds like excess crankcase pressure....
11/10/2022 4:48 AM
Yes. The manufacturer can. Make the call.
11/10/2022 7:15 AM
11/11/2022 2:39 AM
How did the phone call go?
11/13/2022 8:50 AM
Excessive crankcase pressure is the most likely cause.
Using wrong oil could also be a cause.
The link that SE provided give a very logical and simple way to diagnose this problem.
Good Answer SE.!
11/18/2022 6:32 AM
<deleted>
Register to Reply 6 comments
Anonymous Poster (1); HiTekRedNek (1); PWSlack (3); SolarEagle (1)
