Previous in Forum: Nuisance trippings   Next in Forum: 6MHz 20W +/-100V RF Generator Design Required for Ion Trap
11 comments
Enraf ATG854 communication issue with DCS system
12/14/2022 2:56 AM
Hi,
I am facing a problem with the level transmitter Enraf ATG854.
the enraf send data to the CIU prime 880,then the CIU prime send data to the serial card of our DCS system.
we have 3 enraf transmitters each one one is installed in a tank.
Now the 3 enrafs shows the same value in the DCS ,it seems that the communication is lost .
can you please help me?
thanks
Re: Enraf ATG854 communication issue with DCS system
12/14/2022 3:07 AM
you need to troubleshoot your transmitters....
Here's the manual...you might need to replace the circuit boards...
https://www.nexinstrument.com/assets/images/pdf/118_4416220_Rev08.pdf
12/14/2022 3:47 AM
i have to specify that the transmitters are showing good values on the field.
do i have to check some special parameter or alarm in the transmitters?
thanks
12/14/2022 4:38 AM
12/14/2022 4:42 AM
Make sure the original commissioning records for this equipment are to hand.
12/14/2022 4:50 AM
Hi ,
unfortunately this is the problem,i dont have the original commissionning document.so i cant know the meaning of registers 30115 and 30116 sent by the enraf and shown in the DCS block
12/14/2022 7:17 AM
Someone at Honeywell will. Start making calls.
Please let the forum know the final outcome, as this will be valuable to others.
12/27/2022 7:38 AM
Hi,
i have found the data base but i can not communicate with the CIU prime and CIU to diagnise ,i have changed the port com parameters,but i can not communicate,which port i have to choose to communicate?
Regards
12/30/2022 5:13 PM
<deleted>
12/30/2022 5:15 PM
The best port to use hasn’t changed. Pick up the phone and talk to Honeywell.
12/30/2022 5:49 PM
Hi,
i am trying to get help from people who have experience with enraf ciu cards,in parallel we are in touch with honeywell to prepare a support contract.it will take lot of time to prepare the contract and my managers are upset
thanks
01/03/2023 10:10 AM
<...managers are upset...>
Well, that's not the fault of any contributor to this forum, and potential liability is avoided by its contributors having usernames instead of real ones.
Register to Reply 11 comments
Anonymous Poster (1); PWSlack (5); SolarEagle (1); timalg (4)
