Previous in Forum: SVT marine loading arm   Next in Forum: What is the Name of the Opposite of a Rubber Grommet to Protect an OD Edge?
8 comments
Good Answers: 32
High Frequency CFC for 1pA to 10uA range Current Signal
06/27/2023 4:14 AM
Hello,
There is need of a High Frequency CFC for 1pA to 10uA range Current Signal.
1MHz or 10MHz range full scale CFC is ideal. Any design ideas?
VFC can also be used along with IVC.
QFC can also be used.
Re: High Frequency CFC for 1pA to 10uA range Current Signal
06/27/2023 7:12 AM
Would this be for monitoring heartbeat...?
06/27/2023 6:34 PM
I know this probably isn't the application, but the method might give some ideas....
Good Answers: 32
07/08/2023 10:49 AM
No, sensor signal in pA to uA current dynamic range to convert into TTL frequency source for opto isolation.
06/27/2023 6:55 PM
Is this for your ion trap? I am not familiar with CFC, VFC, IVC or QFC.
Do you have an electrical schematic for the trap? And are you suppose to feed it with 200 V @ 6MHz? Where are you getting your specs from?
Is this a commercial manufactured trap or a home brew trap? Perhaps the previous owner/user or manufacturer could help you.
06/27/2023 8:16 PM
Cross frequency coupling (CFC): – Interaction between oscillations at different frequency bands...
https://www.mcgill.ca/bic/files/bic/cross_frequency_coupling_soheilasamiee.pdf
... three different methods of flow rate regulation of a centrifugal fan system: by using a VFD, by using an inlet guide vane (IVC) and by throttling....
https://iopscience.iop.org/article/10.1088/1757-899X/595/1/012012/pdf
... Quantum frequency conversion (QFC) that enables quantum state preservation during frequency conversion is crucial in quantum technology.....
https://www.nature.com/articles/s41534-023-00704-w
06/28/2023 6:47 AM
CFC: Current to Frequency Converter
VFC: Voltage to Frequency Converter
IVC: Current to Voltage Converter
QFC: Charge to Frequency Converter
Good Answers: 32
07/08/2023 10:51 AM
Current to Frequency converter. 1pA to 10uA range.
06/28/2023 2:53 AM
<...There is...need...> to translate the following acronyms:
  • <...CFC...>
  • <...VFC...>
  • <...IVC...>
  • <...QFC...>
Otherwise it is not fair to the reader who is hoping to learn something from the thread.
<...1MHz or 10MHz...> is well within the domain of commercially-available bench-top signal generators.
Register to Reply 8 comments
Haymaker (1); PWSlack (1); Randall (1); Shyam (2); SolarEagle (3)
