Previous in Forum: I need RX-1M1008FE quantity 100 numbers Ohmite resistances   Next in Forum: The future of AI and Robotics?
Human Remains after implosion
07/10/2023 7:48 AM
The Ocean Gates submersible imploded at an unknown depth, and possible human remains have been recovered.
How would they even be identifiable after exposure to those depths/pressure?(approx. 6000psi).
Perhaps jewelry, clothing, or teeth fillings would survive intact, but human flesh and bone would be unidentifiable, even with DNA.
Have scientists ever exposed mammalian flesh to those kind of pressures?
Perhaps, for instance, in a lab using pork cadavers, etc.?
I know the people did not suffer, for the collapse happened in less than .001 seconds. Not even time to blink.
Re: Human Remains after implosion
07/10/2023 8:51 AM
Liquids and solids are not affected by these pressures, only gasses. The human body is made of solids, liquids, and gas within the lungs, sinuses, and digestive tract.
The gas is the problem and the adiabatic compression to 400 atmospheres in one millisecond would generate considerable heat (~1500oK), which would be quickly quenched by the cold seawater.
https://www.reddit.com/r/theydidthemath/comments/14hg2c2/request_how_hot_would_the_air_inside_the_titan/#
Since your DNA is in every cell of the body, I can imagine that some recoverable remains could still be on the pieces of the submersible that were recovered.
07/10/2023 11:21 AM
Here is a video of a steel ball collapse under high pressure. If it was evacuated(no gas inside) before the pressure was applied, it would be much worse.
The crushing of the bodies would principally be done by the surrounding shell, rather that the pressure itself. Imagine a 2000 mph crash into a solid object.
https://www.google.com/search?client=avast-a-3&q=steel+bal+collapsed+by+high+pressure&oq=steel+bal+collapsed+by+high+pressure&aqs=avast..69i64.4j0j1&ie=UTF-8#fpstate=ive&vld=cid:52d13d5d,vid:BnUCmmHxHZA
07/10/2023 3:46 PM
2000 meters (from the video) is approximately 200 atmospheres pressure. If the steel ball were evacuated, it would have a differential pressure of 201 vs. 200 atmospheres. If it were solid steel, it would be unaffected.
I agree, when the structure failed, the bodies were slammed with carbon fiber or a wall of water. At that speed, it doesn't make any difference. It's not just the static pressure but the dynamics.
Register to Reply 3 comments
