Previous in Forum: Time delay for power contactor   Next in Forum: Micro USB 3-B extender cable
26 comments
Bizarre Behavior From Incandescent Neon Lamp
07/25/2023 11:23 PM
I have a hair dryer that has a cord with a GFCI plug on it. Also installed in this plug is an incandescent neon bulb that serves as a night light. Since I got the hair dryer, the lamp has glowed 24/7.
About a month ago, the lamp started flickering. I assumed that it was on the way out, but didn't do anything about it. Next I noticed that the light stayed on continuously when the bathroom light was on, but it would flicker and go off at night.
Most recently, I bought a battery-powered WaterPik. It has a charger that attaches to the side of Waterpik with a magnet. When the charger is charging, there is a blue indicator light that flashes to tell you that it's charging.
Last night, after I got in bed and turned off all the lights, I noticed the blue light flashing, indicating that the Waterpik was charging. What surprised me though was that the orange neon light was also flashing in sync with the blue light!
I'm stumped! I don't believe that there is any kind of photocell or light sensor for the neon light, yet it seems to react to the light from the charger.
How can this be??? Both are plugged into the same GFCI-protected wall outlet. Perhaps I'll plug the charger into a different outlet and see what happens.
Any ideas?
Re: Bizarre Behavior From Incandescent Neon Lamp
07/26/2023 12:16 AM
What medications are you on?
Good Answers: 145
07/26/2023 7:22 AM
"Incandescent" has a hot filament, "neon" has a bunch of little atoms that get so excited that they glow. I'm going to guess that it is neon.
A very small leakage path can cause the neon to glow. Somehow that is probably your answer. I'll guess that your neon lamp is on the borderline of lighting with no external influences. If the bathroom light is a LED then it probably has a switching power supply adding noise spikes to the power line (or ground). Those spikes might be enough to fire a neon lamp that is almost firing. I don't have a theory for the hair dryer, but something about the hair dryer's GFCI, or possibly the addition of the inductance of the wires is affecting voltages or acting like an antenna.
We used to describe unstable circuits as tripping when "Elvis was in the building". For all practical purposes, that might as well be considered to be a true statement. I had some open circuit CMOS once that would trip whenever I bent over to try to figure it out. In this case there was enough static electricity in my hair that by bending over I changed the electric field on the work bench and tripped the circuit. After figuring this out, I could comb my hair and wave the comb back and forth over the circuit. The CMOS would trigger exactly synchronously with my comb's movement. It was magic, well, physics is the proper term, but it still seems like magic.
If you do try to figure this out, remember that there is no such thing as "ground". "Ground" is something we made up to make us feel better while we were dealing with a complex world. The "ground" wires have resistance, inductance, capacitance and time is required for "signals" to travel. "Ground" wires inductively and capacitively couple to other wires and energy sources. Just because they are tied to a ground rod at the building's service entrance doesn't mean that they are not a participant in unusual behavior.
07/26/2023 10:46 PM
"Incandescent" has a hot filament, "neon" has a bunch of little atoms that get so excited that they glow. I'm going to guess that it is neon." --BruceFlorida
I know, but Wikipedia and DigiKey refer to them as 'Incandescent Neon Lamps'. Sounds odd to me, but I'm trying to use the proper terminology.
07/26/2023 11:19 PM
Neon lamps have been around for at least 60 years. They are known for flickering when highly used or not enough current. To add the name incandescent after 60 years is not proper!
07/27/2023 12:31 AM
My experience is that the ground side of the wiring is the problem half or more of the time.
07/26/2023 8:23 AM
External light lowers the striking voltage, the voltage required to ionize the neon atoms so that the gas conducts electricity.
"The lamp glow discharge lights at its striking voltage.[6] The striking voltage is reduced by ambient light or radioactivity. "
https://en.wikipedia.org/wiki/Neon_lamp
07/26/2023 12:09 PM
The Waterpic is radioactive ??
07/26/2023 4:55 PM
07/26/2023 1:04 PM
The behavior of light changes when observed, I'm thinking if you stopped looking at it, it would stop this behavior.... These are electrical field variations intermingling and causing electromagnetic field fluctuations resulting in induced harmonic wave propagation....
07/26/2023 4:28 PM
It's called "Dark Effect"
“Dark Effect: All ILT Neon lamps are subject to a condition called dark effect. Dark affect is defined as a drastic increase in the amount of voltage required to make a lamp glow when the lamp is in a dark environment. Because the lamp is photosensitive, it may require many additional volts to start if no light is present. Neon lamps can also become erratic in total darkness. To prevent dark affect an external source may be run near the neon lamps or in some cases, custom Neon lamps can be supplied with a radioactive gas, often Krypton 85.”
Note that connected to 60Hz, the neon lamp has to restart 120 times per second.
https://www.electronicsweekly.com/blogs/engineer-in-wonderland/general-engineer-in-wonderland/neons-dont-work-in-the-dark-2013-11/
07/26/2023 10:52 PM
Thank you to all who replied!
Perhaps I'm not crazy, although my wife thinks I am.
It really is a strange phenomenon to watch, sort of like lightning bugs causing other lightning bugs to illuminate.
Good Answers: 27
07/27/2023 3:00 AM
What you may be calling as incandescent light is actually the old NE2 lamp which I believe is a helium neon lamp that is being used as pilot light in the olden days.
It normally flickers after awhile of being continuously on for quite some time.
vsar
07/27/2023 8:45 AM
See post #8.
Good Answers: 27
07/28/2023 1:37 AM
NE2 lamp has no filament, just 2 electrodes surrounded by gas which is probably helium...
vsar
08/01/2023 6:59 AM
<...helium...> or <...neon...>?
It's unlikely to be both.
07/27/2023 3:44 AM
If you have the time and are so inclined...try to tune it.
Replace the series resistor with a pot set at the resistor value. Wait for blinking. Slowly adjust pot for stop blinking, if it will. This might not work. Turn all other junk on to check blink. Replace previous resistor with pot value. You might find a current sweet spot for your needs.
Don't try it unless you're familiar with power line AC. Around water.
I didn't realize I was so ignorant about these bulbs. Used them all my life. I never had a blinking complaint. Quite finicky it seems.
07/27/2023 4:00 AM
Neon lamps;
1;have 2 electrodes inside the glass envelope surrounded by neon gas with a typical striking voltage of 70volts RMS.
2; have a central electrode with a perforated screen around the outside as the second electrode.
3; have 2 electrodes one in the center and a cap above the electrode.
4; have one electrode and a portion of the glass is coated with a conductive paint, silvering or aluminium and relies on the glass to form a capacitive connection.
The ones with two electrodes need either a ballast resistor to limit the current or if on AC a capacitor with the right impedance, all very arbitrarydepending on cheapness.
Any of the above electrodes can be treated with an emissive coating, used to be Thorium or some other radioactive coating. If the electrode/s are white couloured then usually that is a sign of a coating to increase the ionisation of the neon.
With all the varied types any stray capacitance can excite the neon or even photons of light striking the gas. Magnetic coupling to the wires inside the plug from the core balance Measurement system could also cause the flickering.
I know our American friends don't have isolating switches included in their plugs but why do you leave the hair dryer plugged into the outlet when not in use for the protection in the plug could fail and result in a pyrotechnic conflagration leading to self immolation! Trust not the socket to not leak electrons which may pool in a low spot.
Hare today, goon tomorrow!
07/27/2023 7:39 AM
One of the solutions to the problem is a dob of opaque paint.
07/27/2023 8:49 AM
Actually, I do like the night light feature, but it's way too bright. I have previously covered it with black electrical tape with a small hole in it to limit it's light output to a tolerable level.
07/27/2023 10:11 PM
I've experienced this effect many times. I currently have at least two power outlet strips, one is a surge protector, the other is just a power strip, that exhibit the effect. Just a couple of days ago, one of them came on at normal brightness for a short while (several minutes), for no obvious reason, then returned to its failed state.
If you find it too bright, and you are at all electronically knowledgable, you can insert a diode, capable of blocking at least 180 Volts. in series with the lamp, so it will only illuminate on half of the powerline voltage peaks. The peak voltage of 120VAC is around 160 Volts, so the 180V value gives a safety factor.
If you happen to be in a location where the power line voltage is 240 Volts, then double the rating of the diode.
It will actually be glowing at the same brightness, but only half as frequently. If the flicker doesn't bother you, it will seem half as bright
Good Answers: 116
08/04/2023 7:08 AM
Wictionary writes "incandescent" comes from Latin meaning "heat up" or "glow". Glow can apply to glowing neon or very hot filament, so incandescent can describe both!!
As others have replied, neon strike voltage can be reduced by incident light/radioactivity. Blue light has higher quantum energy than red, more able to ionise. Old magazine pictures lose green, red, yellow leaving blue; because blue reflects blue light while other colours absorb it and fade.
A magnet can affect electron motion/velocity, so may also affect neon.
08/04/2023 10:34 AM
I checked several other dictionaries; their definitions of incandescent all included the term "with" or "due to" intense heat. Neon lamps, and especially NE2s, do not have/use intense heat.
I agree with others here that using the term "incandescent" is NOT appropriate when referring to a neon lamp.
A carbon arc lamp produces light with very intense heat, but I've never heard one referred to as incandescent. I stick with incandescent lamp meaning a lamp the produces its light by heating a filament.
Good Answers: 116
08/04/2023 11:36 AM
dkwarner,
Agreed, found latin word means growing warm or kindling - all heat but not necessarily intense - no heat needed for neon to glow.
67model
08/04/2023 12:18 PM
I checked with a company that sells them (Digikey). They probably know more about it than a company that prints dictionaries.
Good Answers: 116
08/04/2023 12:39 PM
Steve45,
You misunderstood - Digikey put filament and neon lamps in the same group [because obsolescent?] - the comma is important! Choosing NEON gives list of 70 all called "LAMP NEON" - most marked "not for new designs".
67model
  1. Product Index
  2. Optoelectronics
  3. Incandescent, Neon Lamps
Share
Results: 1,239
08/04/2023 4:14 PM
My intent was to differentiate it from a neon sign, so I looked at a vendor and did a search for 'neon lamp'. The ONLY category that popped up that mentioned the word 'neon' was 'incandescent, neon lamps', so I went with that.
It sounds like everybody here knows what I'm talking about, so I'm done.
Register to Reply 26 comments
67model (3); Brave Sir Robin (1); BruceFlorida (1); dkwarner (2); Haymaker (1); PWSlack (2); Rixter (2); silvCrow (1); SolarEagle (3); StandardsGuy (1); Stef (1); steve45 (6); vsar (2)
