Previous in Forum: Vogtle Unit 3 Goes On Line   Next in Forum: Cell phone wireless charging and air gaps
Universal USB adapter
08/01/2023 2:50 PM
I have searched diligently for a universal USB adapter for all of the USB types that will charge as well as permit data transfer.
I have seen the individual adapters,but I am looking for a single adapter that has female and male ports for all of the USB types, but not a hub.
Seems simple enough,but I cannot seem to find one.Perhaps I have overlooked it.
Thanks in advance for all help on this matter.
Pathfinder Tags: universal usb adapter
Re: universal usb adapter
08/01/2023 4:16 PM
Probably a kit is the best you can do...
08/01/2023 5:38 PM
GA, I suspect that an "octopus" adapter cable would not fare well with high speed data. Those are probably only suitable for power/charging.
08/03/2023 9:12 AM
You are probably right,the octopus cables I have seen are for charging only,so there must be a problem with data.
The problem may be with the shielding within the common conductors.
Perhaps a rotary switch to select and isolate each device's data lines.
Idle data lines could be terminated with a shunt or a resistor/capacitor of proper value to prevent "echos" on the line.
That may not be practical,and has probably already been tried.
I am probably trying to re invent the wheel.
08/03/2023 9:01 AM
It would seem to be a simple matter to make an adapter like this.
All have the same type wiring:2 pair,shielded.2 Signal,2 power conductors.
The main difference I see is the physical shape and pin out of the different adapters.
I am tempted to try to make one using a terminal block just to see how the unused ports will affect the speed.
If it works out,then I will make M F connectors to match in one enclosure.
Of course,I do not understand all I know about this,as usual,it is much deeper than it looks: "Like the mud puddle."
Any feedback on this is greatly appreciated.
Re: Universal USB adapter
08/18/2023 7:09 PM
Charging Cable
Will this work for you?
08/19/2023 8:08 AM
This might just do it! I will look at it further when I have the time.!
THANKS!
Register to Reply 6 comments
Brave Sir Robin (1); Deefburger (1); HiTekRedNek (3); SolarEagle (1)
