Previous in Forum: Microplastics in the 1700s?   Next in Forum: Fire Ant Colony Destruction
8 comments
Interesting Phenomenon
02/26/2024 11:14 AM
We're all used to air getting hot when compressed and getting cold when allowed to expand. Believe it or not, not all gases behave that way...
https://youtu.be/yYqFkxvTvTg
Re: Interesting Phenomenon
02/26/2024 12:45 PM
Thank you for presenting that
02/27/2024 12:08 AM
Thanks! I was totally unaware of that!
02/27/2024 4:24 AM
Richard Saunders had an interesting response to that sentiment
02/27/2024 12:32 AM
It is a well known fact that some gasses do not follow the normal thermodynamic rules of gasses. When you calculate the state of a gas, you would normally use an approximation known as the ideal gas where the standard equation holds --> pV=nRT
This usually holds for monatomic gasses at high temperatures and low pressure. When the molecular size and intermolecular attraction becomes important, you need a different set of state equations.
03/10/2024 7:02 AM
I never understood how the ideal gas law would explain how a gas cools when it expands. Now I see that it's the gas deviating from the ideal gas law that explains it. An ideal gas would neither cool nor warm on expansion.
03/10/2024 10:13 AM
Nature is constantly seeking equilibrium.Mountains erode,a liquid will form a perfect sphere in the absence of gravity or other outside forces.
Two reasons(but not necessarily all) that a gas could expand.1.Higher pressure inside the container than outside, caused by heat or adding gas to the confining space or a decrease in outside pressure.
Our universe is expanding and it could be that the BB is still happening,or the "Void" that surrounds our universe is at a lower "pressure" than our universe.
A bubble will increase in speed as it rises due to a decrease in external pressure and the corresponding increase in volume of the gas.
A balloon will expand due to an increase in the quantity of internal gas,at a constant temperature.
That kind of sounds like our universe expansion.Perhaps we live in a bubble that we cannot see because the "Void" is our dimensional boundary.
02/27/2024 6:34 AM
Since there was no molecular motion (heat) within the Big Bang,(or a black hole) the temperature should have been cold when it expanded?
The lowest natural temperature in the visible universe is a gas cloud resulting from an explosion (rapid expansion). The Boomerang Nebula 1 degree K.
https://interestingengineering.com/science/what-is-the-coldest-place-in-the-universe
03/01/2024 12:11 PM
Physics can be fickle…
just like Newtonian and non-Newtonian fluids…
and by fickle, I mean interesting…
Register to Reply 8 comments
abotha (1); dkwarner (1); HiTekRedNek (2); JWthetech (2); phoenix911 (1); Rixter (1)
