Previous in Forum: Highly Backdrivable, Fast and High Torque Manipulator   Next in Forum: Support for Vertical Vessel
Lower Viscosity of Refrigeration Oil
04/05/2024 12:09 AM
Can a oil has been toped up having higher viscosity (same brand, same typ) in place of lower viscosity ( same brand, same type) to maintain /compesate viscosity?
ahb
Re: Lower viscosity of refrigration oil.
04/05/2024 12:58 AM
No
04/05/2024 6:55 AM
It is far better to drain it out entirely, and replace with the correct grade of oil. Equipment manufacturers can generally walk away from any warranty claims after failure if the wrong grade of oil has been attributed to the warranty call-out.
If in doubt, refer to the equipment manufacturer's operation and maintenance manual, which should have been supplied with the equipment. If it isn't available, start with a phone call to the equipment manufacturer to obtain a replacement as a high priority.
Re: Lower Viscosity of Refrigeration Oil
04/06/2024 5:08 AM
Most people are confused about oil viscosity.Here is a link to a very interesting and informative white paper on oils in general,and tells you everything you need to know about oil viscosity,multi-viscosity oils,single viscosity and why there are different grades of oil.Bob THE Oil Guy really knows his stuff.It is divided into chapters detailing the many characteristics of the different oils.Chapters 2 and 3 are very relevant to this discussion.
No chemistry lessons required,it is written in simple language.
I recommend it to anyone curious about motor oils and lubricants.
Refrigerant oils are especially peculiar and specialized in their characteristics and should not be mixed or substituted.
https://bobistheoilguy.com/motor-oil-103/
Register to Reply 3 comments
gutmonarch (1); HiTekRedNek (1); PWSlack (1)
