Previous in Forum: Cable Tray Threaded Rod Calculation   Next in Forum: GE Protection Relay-Password Recovery
8 comments
Battery Life Span
08/09/2024 6:41 AM
We need life span of this battery. If somebody knows please share me
We have battery as under specifications:
Motive T-125
6volt 240Ah
Re: Battery Life Span
08/09/2024 7:25 AM
It depends upon the following, details of which have been withheld from the forum:
  • Temperatures
  • Humidity
  • Vibration
  • How long it has been in storage prior to use
  • In what condition it was left in storage
  • How many times it has been fully discharged
  • How many times it has been short-circuited
  • Etc.
All of these things are facility-specific, and the best source of information on them is the <...We...>.
<...life span...>
In what sense (also withheld from the forum)?
  • If it were abused and operated well out of its specification, for instance, subjected to fire and deep freeze, dropped from a great height, shorted and shorted and shorted, then it might last a couple of days.
  • If it were used as a door stop, for instance, its life would probably outlast the door that it were stopping.
08/09/2024 12:38 PM
...."The life expectancy of batteries is very dynamic and depends on a number of application specific variables such as the proper sizing of the battery bank, depth of discharge, type of loads, battery maintenance regime, ambient temperature, and charging algorithm."...
However, generally speaking 4 - 8 years...on average..
https://www.trojanbattery.com/resources/battery-maintenance
Good Answers: 27
08/10/2024 9:12 AM
The typical battery usable life expectancy will normally depend upon the type of chemical used, and how the battery is maintained in the environment of application..
Lithium-ion type can last at least 3X to 4X more than the regular lead-acid storage type of battery assuming proper application and normal usage environment..
vsar
Good Answers: 27
08/30/2024 7:29 AM
Additionally, batteries do normally have shelf life, which may affect the useful operational life expectancy that can be expected regardless of the printed technical specifications..
Which means that batteries may have a shorter span if has been stored for awhile before being installed and put into operation..
vsar
08/10/2024 5:54 PM
Good Answers: 22
08/11/2024 3:12 AM
It is a flooded Lead acid tubular type battery meant for automotive applications. I don't think it will last over 5 years. You can check the Trojan battery, UK literature.
Raghunath
08/15/2024 9:57 AM
How did the telephone call with the battery's manufacturer go?
08/30/2024 12:13 AM
MOTIVE T-125 data sheet:
https://www.batterysystems.net/amfile/file/download/file/122/product/658/
Register to Reply 8 comments
normnet (1); PWSlack (2); raghun (1); Rixter (1); SolarEagle (1); vsar (2)
