Previous in Forum: Interesting Puzzle   Next in Forum: Electromagnetic Vortex Cannon
14 comments
O2 Apocalypse
09/14/2024 9:17 AM
I have to admit being a bit weird at times!
A couple of mornings ago, I awoke with the craziest thing going through my mind.
Given that we have just recently lived through a pandemic, what's next?
What would happen if some nefarious actor created a means (bacteria, virus, ... whatever) that would sequester Oxygen from the atmosphere at a rate faster than it is being provided by plants?
Given that life has evolved to expect the current level (just under 21%) what would the effects be of a perhaps rapidly decreasing oxygen level? What level would it be where effects would be obviously apparent?
If such an event could happen, what would the effects be on society? What measures would governments take to attempt to moderate the symptoms?
(Yes, ChatGPT has a long and interesting response, but I would like to hear other thoughts.)
As I said: a CRAZY thought process
Regards,
Bill Lee
BillLee
Pathfinder Tags: apocalypse oxygen
Re: O2 Apocalypse
09/14/2024 9:22 AM
when you don't know what your fighting, its pretty hard to defend against it...
Nature has a way of healing itself. just keep in mind, like global warming, humans may not be a part of its future.
Re: O2 Apocalypse
09/14/2024 12:21 PM
The world as we know it is mostly made up of oxygen, so a shortage is just not a scenario that seems even remotely possible....
..."Below 19.5 percent oxygen . . . , air is considered oxygen-deficient."...
Re: O2 Apocalypse
09/14/2024 3:59 PM
Oxygen is the most abundant element in the Earth's crust. (None of the "abundance" sites I found clearly explained whether the ocean is part of the crust. I suspect much of that crust oxygen is the oceans' water. I expect that silicon oxide compounds are still the most abundant source of crustal oxygen. The solid crust volume is larger than the ocean volume.) Nitrogen is the most abundant element in the Earth's atmosphere. The most massive part of the Earth is the core. The most abundant element in the core is iron. The mass of the Earth's core dwarfs the crust and atmosphere combined. Iron is the most abundant element in the Earth.
Re: O2 Apocalypse
09/14/2024 7:40 PM
Iron is a key component of hemoglobin, a protein in red blood cells that binds to oxygen molecules and carries them throughout the body...without the iron, oxygen would be useless to us...
Re: O2 Apocalypse
09/16/2024 6:11 PM
Of course that is at sea level, as you gain altitude oxygen and other gases decline as a percentage...and humans can adapt to much lower levels of oxygen...at around 18,000 ft you drop to about half that, or 10.5%....on Mt. Everest at 29,000 ft it drops to 6.9%...as you know from watching tv and movies, that at 10,000 ft of altitude you can remove your oxygen mask...haha
Haha just kidding, as you can see we have oxygen on....
https://hypoxico.com/pages/altitude-to-oxygen-chart
Re: O2 Apocalypse
09/18/2024 3:22 AM
Just to say that i think this is a misreading of the chart
Oxygen is always 21% (more or less I think as oxygen is heavier than nitrogen gravity may have a small effect)
The chart you liked to is Effective Oxygen %
At the summit of Everest atmos pressure is 0.35barA (5psia) so approx 1/3 sea level
Your lungs have the same volume (typically 6l) at the top of Everest so for each breath you take in there is only 1/3 the amount of oxygen that there would be in that breath at sea level.
So if you want to train for Everest at sea level you need a chamber that has an oxygen content of only 7%. It wont be a true reflection - I am not sure what impact the low atmos pressure has on gas transfer in the lungs - but it will reflect the difficulty of getting enough oxygen into your lungs and so into the blood stream
Re: O2 Apocalypse
09/18/2024 11:33 AM
I was referring to percentage of comparable volume...thanks for the clarification...
Re: O2 Apocalypse
09/14/2024 11:16 PM
What question did you give ChatGPT? It would be interesting to give that same question to CoPilot and a couple of others to see what they have to say. Something I saw not long ago (here???) said that AI responses may be subject to hallucinations!
Lehman57
Good Answers: 94
Re: O2 Apocalypse
09/16/2024 4:12 AM
Who leaked my plans to you? It's tough enough being a master criminal with everyone posting their lives online, I can't even keep world domination under wraps these days.
Re: O2 Apocalypse
09/16/2024 11:03 AM
Re: O2 Apocalypse
09/16/2024 5:32 PM
I guess the place to start is to ask where the oxygen originally came from. Our planet is the only planet in the solar system with a large percentage of oxygen in its atmosphere.
https://physoc.onlinelibrary.wiley.com/doi/epdf/10.14814/phy2.15214
Re: O2 Apocalypse
09/17/2024 1:31 PM
...."Stromatolites are thought to be 3.5billion years old. They are living rocks and produce oxygen. Only found in a few places in the world, these are in Western Australia. It is thought they produced the oxygen which brings the total on earth up to 20% These rocks are alive and still producing oxygen today."...
..."Stromatolites are layered sedimentary formations that are considered to be the oldest fossils on Earth, dating back over three billion years. They are formed by photosynthetic microorganisms, such as cyanobacteria, that create adhesive compounds that bind sand and other rocky materials together."...
Re: O2 Apocalypse
09/17/2024 2:41 PM
Re: O2 Apocalypse
09/16/2024 9:10 PM
Well I guess we would all be wearing these portable oxygen concentrators...
Register to Reply 14 comments
Lehman57 (1); Nigh (1); phoenix911 (2); redfred (1); Rixter (1); simonsd (1); SolarEagle (7)
