Previous in Forum: Is the Earth Shrinking, or is the Sea Rising, Both or Neither?   Next in Forum: Gas Valve
18 comments
Hobbies - CNC - New Member
Eroda Spark Eroder Machine
11/04/2024 12:19 PM
Can anybody please help me to get a wiring circuit diagram for an Eroda EDM. The machine serial number is 81035. The company who made the machine was Eroda Machinery Ltd UK, but they have been dissolved.
I have tried all I could without success, this is my last effort.
The machine is eroding extremely slowly and I have tried to check the circuit but it is fairly complicated as the wires are not marked and all are the same color. The transistor markings have also faded totally.
Johan van Niekerk
Pathfinder Tags: EDM eroda sinker spark eroder
Re: Eroda Spark Eroder Machine
11/04/2024 1:26 PM
Have you tried this?
https://www.erodatoolsltd.co.uk/contact-us/
11/04/2024 11:52 PM
Yes I have tried them.
Johan van Niekerk
11/04/2024 7:12 PM
Maybe you need to change your fluid...
https://www.slideshare.net/slideshow/edm-and-wire-cut-edm/250624064
...or maybe track down and ask one of these guy's....Ken or Tony Rolfe...
https://www.erodatoolsltd.co.uk/about-us/
I think you have the manufacturer name wrong possibly, they seem to only do contract work....is it possible?
https://www.erowa.com/en/solutions/sd/erowa-wire-edm-tooling-system
11/05/2024 4:17 AM
Hello Johan, the company still exists, they are based in Sheffield, UK.
Here is their Website address Erodatoolsltd.co.uk
Their telephone number is ++44 1226 763725
Hope this helps.
11/05/2024 11:24 AM
thanks for the reply but it is not Arodatools.
The description on the machine is:Aroda.
N.E. Eroda Machinery Ltd, Electro Discharge Equipment.
Unit D Taoman street, Wakefield WF1Sou, Yorkshire.
I do not know if this is helpful.
Regards.
Johan van Niekerk
11/05/2024 12:08 PM
I would try these guys....
https://www.edmplus.co/uk-ltd/
11/05/2024 3:30 PM
Hi Johan, in your opening post you wrote "Can anybody please help me to get a wiring circuit diagram for an Eroda EDM" using the word Eroda, now you are using a completely new word " Aroda".
Please confirm which machine you have, maybe a foto of the Data Plate information would be helpful !
BR
Norman
11/05/2024 11:45 PM
Please excuse my finger problem, it is ERODA
Johan van Niekerk
11/06/2024 3:51 AM
They have gone out of business three times, and each time they change the name slightly, and start a new business...
N.E. ERODA MACHINERY LIMITED, 10 Sep 1973 - 21 Mar 1991 ...
ERODA HOUSE LIMITED till 2011
N.B.ERODATOOLS LIMITED27 Jan 1972 - 23 Oct 2020
Eroda Tools Limited...
https://find-and-update.company-information.service.gov.uk/company/01040150
If I were to guess, I would say the private company owns the public company/companies that keep failing...this is probably designed as a liability dodge...so good luck trying to deal with them directly...what you need is a specialist that can redesign or replace the part/or parts that have failed...would be my advice..or you can keep trying to figure it out yourself...this all depends on financial means at your disposal...
11/06/2024 9:05 AM
11/06/2024 9:24 AM
11/06/2024 11:05 PM
11/06/2024 5:02 AM
Although the wiring diagram might help: what you really need is the circuit diagram for the pulse generator PCB.
Just looking for any EDM pulse generator circuit diagrams on the net might help.
But there might be a short cut: does the PCB have any Aluminium Electrolytic capacitors on it? If so replace them. Exact equivalents will do, but if you can get higher temperature/longer life versions they will last longer. Better still would be to replace them with equivalent voltage and capacitance MLCCs (MultiLayer ceramic Capacitors) but this might be impractical.
This "fix" works for loads of "power supply" type problems. Often you can spot the dried out capacitors because their cans are "rising up" off the PCB.
11/06/2024 8:18 AM
Hi Johan, I contacted the company in Sheffield to see if they could help but No-Go unfortunately.
Here is their reply.
Hi Norman,
No unfortunately that was a different company to ours and we are not affiliated in any way (there were two separate companies set up by brothers who had fallen out). Eroda machinery has long since been out of business so sorry but we cannot be of any assistance.
Best regards,
Caroline Healey
Works Manager
If I understand your orginal post the machine works but is slow.. maybe you could try to find out which parts / components would make it slow.. I don't recall if you said how old the machine is, maybe when it was built, it was the normal speed ?
Guess you can try Randall's suggestion !
BR Norman
06/09/2026 10:28 AM
Hi
I only write this reply to explain you will not be able to contact the original company. My farther owned it and he died over 20 years ago. Also, it was not brothers that fell out, not sure why they said that. and the other companies were not tax scams. I don’t know why I feel the need to explain to online sort of hate, but that was my dads and he was in business along time and was legit!! Anyway I do hope you get it sorted.
Good Answers: 25
11/06/2024 10:16 PM
Looking through the indexes of the various EDM books that I have:
Cyssau's L'Usinage et le Durcissement par Etincelage lists an "Erodomatic" machine manufactured by a company named Wickman in England. No wiring diagram.
Spark Machining published by The Machinery Pubishing Co., Ltd mentions the same machine, or family of machines. No wiring diagram.
Neither entry mentions running "too slowly" in its troubleshooting section.
10/23/2026 3:29 PM
Hi Johan
Sorry about the very late reply.
I used to work for Eroda, correct name is N.E.Eroda
whilst they made solid sink machines, the machine range was designated NE 300, NE 350, NE 650 and NE 1000. The number designates the table length on the x axis.
Which model have you got?
There is generally a plate on the back of the machine.
10/24/2026 4:36 AM
Hi Johan, maybe you could post a foto of the data Plate then everybody can see what machine you are referring to.
Also have you looked closely at the PCBA, a lot of companies printed their name and ID number on the PCB so you could maybe trace the PCB manufacturer who would have a copy of the wiring diagram, assuming they still exist !
Register to Reply 18 comments
Albyt1 (1); Johan van Niekerk (3); JWthetech (1); naddy1974 (1); piolenc (1); Randall (1); SolarEagle (6); The Wizard (4)
