Previous in Forum: URANUS Flatulence: Is There a Comedian in the Audience?   Next in Forum: Model for a Pulse Detonation Turbo Driven Axle Engine
Hybrid Turbo Jet Engine
11/16/2024 3:29 AM
This sounds amazing, hope it pans out....quite a leap in efficiency if it does...
..."Traditional turbojets, like you'd see in fighter planes, use the exhaust gas to spin the compressor fan to draw in air. More exhaust equals more speed. And a turbojet is efficient at supersonic high speeds – slow speeds, not so much. The turbojet struggles to compress enough air for efficient combustion and wastes significant amounts of fuel.
The Concorde, for example – a supersonic commercial passenger aircraft in operation from 1976 to 2003 – was notorious for its fuel inefficiencies. It's was said to use around 2 tons (627 gallons / 2,372 liters) of fuel just to taxi to the runway from the gate, highlighting how incredibly inefficient turbojets are at low speed.
A turbofan engine, on the other hand, is designed to move huge amounts of air to propel an aircraft forward. At lower subsonic speeds, it does this quite well. Faster than that, aerodynamic drag created by the large fans that aren't optimized for fast flight creates an efficiency and operability issue."....
..."Astro Mechanica's engine operates in three distinct modes:
  • Mode 1 uses an electric motor to spin the "blisk" – a bladed disk the company makes in-house that acts as the compressor/turbofan instead of traditional fan blades – without active combustion, perfect for efficient ground operations and subsonic flight.
  • Mode 2 introduces turbojet combustion, propelling the aircraft past the speed of sound while an electric motor powers the compressor to the necessary speeds to feed the engine enough air, rather than relying on exhaust gases like a traditional turbojet engine.
  • Finally, Mode 3 is an all-fuel ramjet-like configuration with no moving parts, allowing the engine to potentially reach Mach 3 or faster using only the Ram Pressure effect, where the aircraft's speed forces an immense amount of air into the inlet, providing enough compression for combustion.
With this design approach, Brooke reckons the Concorde would have had 61% more range if it were fitted with the Astro Mechanica turboelectric adaptive engine.....
...Cost-effectiveness is also a major focus of Astro Mechanica's approach. The CFM LEAP-1B engine found in a Boeing 737 MAX costs around US$14 million per engine. Astro Mechanica claims its turboelectric adaptive engines would be significantly less expensive, already supersonic-capable, have fewer moving parts, and likely be cheaper to maintain. Moreover, the engines are designed to run on liquid natural gas (LNG), which is 1/10th the price of traditional jet fuel, offers more energy per unit weight, and produces 30% less CO2 when burned....
...In the near-ish future, Brooke intends to build an experimental airframe powered by four Astro Mechanica turboelectric adaptive jet engines and two GE CT7 engines and flying non-stop-supersonic from San Francisco to Tokyo, collecting data, to really ramp up the company's place in aerospace engineering....."
https://newatlas.com/aircraft/astro-mechanica-turboelectric-adaptive-engine-supersonic/
Re: Hybrid Turbo Jet Engine
11/16/2024 3:18 PM
I'm all for any attempts to produce more efficient engines. However, this marketing article presents insufficient information to convince me that this engine is new or more efficient. Did their efficiency calculations include the fuel consumed to operate the turbogenerator that powers the "blisk" compressor/turbofan? How does the airstream bypass the "blisk" so this engine becomes a ramjet engine at supersonic speeds? How does the turbogenerator cope with the changes in air inlet pressures in subsonic, transonic, and supersonic airspeeds?
11/16/2024 10:48 PM
I wonder where the electricity comes from to run the motor? Maybe normal large aircraft batteries can supply that temporary need long enough to get a generator spinning?
11/16/2024 11:19 PM
I disagree with the statement: "offers more energy per unit weight..."
LNG has less energy per pound then jet fuel and requires cryogenic tanks for storage.
Here is a link comparing all fuels:https://afdc.energy.gov/fuels/properties
11/16/2024 11:55 PM
They will also compare "apples to oranges" in their proposed test aircraft. The GE CT7 is a turboshaft or turboprop engine. The GE engine produces thrust via a propeller. The hybrid engine is supposed to produce thrust itself. Thus all testing will be subsonic and only in mode 1 operation.
11/17/2024 3:30 AM
11/17/2024 4:10 AM
Another company, Hermeus, is working in a similar direction...
Register to Reply 6 comments
HiTekRedNek (1); redfred (2); rwilliams (1); SolarEagle (2)
