Previous in Forum: ABS Sensitivity?   Next in Forum: First Mechanical Qubit
26 comments
Electrostatic Precipitation of Water Vapor from Clouds
11/21/2024 6:56 AM
I recently read an article where MIT is developing a charged grid to capture the moisture form power plant cooling towers,reducing cost of makeup water and reducing total water usage.Sounds like a good idea.The opposite charges are applied to the vapor by a grid,and then as the water vapor passes through the oppositely charged grid it attracts the water and condenses it.
Along those same lines of thought,would an airborne ion generator be useful to create rain from clouds?
Imagine a small plane,pulling a charged net behind it with half of the net positively charged and half the opposite charge.This should result in condensation of the water vapor into solid droplets that would fall as rain.
A simple cheap source of power would be a neon sign transformer with two diodes pointing opposite directions.One cycle would be positive,the next cycle would be negative.Of course,a variable frequency could be used to accomplish the best results depending on plane speed and other factors.
The net could be made from fine tungsten wire or a foil bristle rope like a Christmas tree garland.
Small planes pull banners behind them,so I think the load on the plane should not be a problem.
Or perhaps capturing the vapor trails from commercial aircraft?
I am putting this idea in the public domain to prevent misuse by greedy corporations.
It also might rightfully belong to MIT as this is simply another incarnation of their idea.
What are the forum's thoughts on this idea?
Pathfinder Tags: Electrostatic rain maker?
Re: Electrostatic precipitation of water vapor from clouds.
11/21/2024 7:17 AM
Rainwater harvesting is carried out at high altitudes in the Himalayas, among other places, using a fine mesh made of resilient materials. Water droplets from cloud and mist collect onto the mesh and they drop under the influence of gravity into simple containers for onward use; <...Electrostatic...> action is unnecessary.
11/21/2024 8:04 AM
I am aware of this,but I am talking about a large geographical area,where rain is needed.The Himalayan method is good for local uses,but is reliant on certain conditions of temperature and humidity.
There are rivers of water in the atmosphere that are invisible because they are a gas,not a vapor.A vapor is invisible,like the gap in the steam from a tea kettle,or high pressure steam.A cloud in an amalgam of condensed water vapor and air.Perhaps the addition of an electrostatic charge would encourage condensation of the invisible form of water.
There is more water in the atmosphere in the form of vapor than all the rivers of the world combined.
Cosmic rays ionize clouds and can cause a vapor to condense,so I conclude that ionization from any other source should do like wise.*
*https://home.cern/news/news/experiments/cosmic-rays-clouds
11/21/2024 8:25 AM
Reducing insolation, by introducing large-scale sun-shade (in orbit?) to reduce temperatures, would be another interesting possibility; the ability of air to hold water vapour reduces with lowering temperature.
Introducing sulphur/sulfur dioxide into the upper atmosphere would increase the reflectivity of the atmosphere and lower surface temperatures, though the spin-off would be the turning of blue sky into white.
11/21/2024 11:42 PM
I suspect large geographical area will be a problem.
Assuming a plane could tow the apparatus, it would produce water in strips. I have no idea how much room is needed to turn around to do an adjacent strip,
Any idea how much water is produced? They measure rainfall in acre-feet, which is a bunch of gallons. Guessing, even .1 acre-foot would be thousands of gallons.
How much electrical current would this take? "Electrostatic" gives a false impression that you just charge it up. However, the condensed vapor will drain off the charge, producing a current flow.
Lehman57
11/22/2024 5:13 AM
Large is a relative term,but I mentioned it in reference to the grid collection system in the mountains previously mentioned.
The ionization will require power as the charge is dissipated,but the effect will far exceed the actual static field,like smoke,it will spread as the charge creates larger droplets that can merge and become drops large enough to fall,a domino effect,so to speak.
The amount of power required will depend on the grid area being towed and the amount of available water vapor.A controller can easily be made to accomplish this.
In an area suffering from a drought,I think the cost could easily be justified.
The Colorado river no longer reaches the ocean,and vegetation close the the river is being removed to prevent it from using water from the river. This is an act of desperation,I think.
I remember seeing,many years ago, in a textile operation which an an entire 4 acre room where the static charge of the air was controlled by positive and negative grids inserted into the duct work.
I was not allowed to inspect the system closely,but in passing I noticed what I am pretty sure was a flyback transformer from a TV as a voltage source.
The appropriate voltage was controlled by a very simple controller in the office and the sensors were from a ion smoke detector.The cotton was in a fragile state at this stage of production, with very little twist applied, almost looking like fog, and static discharges could cause the fibers to separate,affecting production.
They discovered the ideal charge rate was slightly negative,and maintained it with this system.The side effect was an accumulation of dust on the walls.Employees were no longer getting shocked when touching metal carts with rubber wheels.
All in all, a very cheap and simple method,using off the shelf components.
Of course there are always the unintended consequences of messing with mother nature when you make it rain artificially,but we will never know till we try.I hope someone with the capital can explore the possibilities of the method.
Farmers could of course,be charged for the rain produced,making the process very profitable. Sort of scary when I think about it with the unbridled greed of big business.
I almost hate I mentioned it now.
A first step to human-controlled weather?
11/29/2024 11:27 AM
It might work, but you have to figure the cost of capturing a gallon of water. Is it economically feasible, compared with, say, cloud seeding?
12/03/2024 12:16 PM
I had read 20-30 years ago where the the next world war will not be fought for land, or oil but for potable water.
One thing is, in the arrid areas where water is needed, one needs the clouds to seed.
12/04/2024 3:14 PM
I think the next war will be via software.
And as far as WW4? Albert E. said he did not know when, but it would be fought with sticks and stones after WW3.
12/04/2024 6:12 PM
That war is on now,… I’m getting a lot of scam calls from the that my Credit Cards has been compromised from security breaches from banking organizations such as Bank of America, Wells Fargo, Chase to name a few the lists are long…
and Al’s correct… just look at the Middle East from a month ago…what an abortion it may settle down now with leadership being put into place… or not. Stopping an abortion is tough.
01/24/2025 7:44 AM
DEI member has spoken, this is off topic.
too bad they were never involved in brain storming… where this happens.
Re: Electrostatic Precipitation of Water Vapor from Clouds
11/21/2024 11:44 AM
The article you read makes no sense. Feed water never gets to or enters the stack. Electrostatics are used to remove particulate matter.
And there are much more PASSIVE ways to condense atmospheric water.
And a passive way to construct a cold sink. No energy required.
It has been discovered that quartz glass can absorb heat and re-emit it at the 10 um slot. This heat is rejected and never returns to earth. The cold temp of space is the sink.
The Sahara is 97% quartz sand. Grinding the sand down to 1 um, and making a paint or a film, can lower the surface temp of a plate of steel, by about 20- 30 degrees F. And supposedly at high noon. A passive cold sink.
In many areas this drop is sufficient to the dew point. And air water will condense on that plate.
Imagine an area in the Sahara with that drop.
This info is about 5 years old. Search for 10 um slot passive cooling for new findings. I have not check since then.
11/21/2024 1:13 PM
This is not about the exhaust stack,this is recovering water from the cooling towers.This water can be used to replenish the cooling tower reservoir.
Here is a link to the article:
https://news.mit.edu/2021/infinite-cooling-nuclear-0803
No mention of boiler feed water or stack exhaust.
11/23/2024 5:07 AM
Having worked on electrostatic precipitators in power plants they are a high maintenance item with often broken wires.
I wonder how they plan to make access easy to the grids or will it be like all engineered systems, never plan for maintenance.
It would be interesting to know the resistivity of water vapour at the exit temperature of a cooling tower.
Hare today, goon tomorrow!
11/29/2024 3:36 PM
I know how electrostatic precipitators in power plants can be high maintenance, due to carbon accumulation and corrosive gasses, but I don't think the cloud precipitation would have the same problems because you are dealing with basically pure water vapor. If service is needed it could be done on the ground, simplifying maintenance when needed.
11/29/2024 3:44 PM
The electrical resistivity will vary in accordance to the relative humidity, which will also vary with temperature, so it is a very dynamic value. In electrostatic precipitation I do not think it will make much difference, it will simply emit more or less ions accordingly.
11/23/2024 8:53 AM
A large slow solar photovoltaic driven drone with batteries might work for this, towing an opposite polarity kite behind above or below. Lots of needle points can create charged particles that could promote the formation of larger raindrops. Could be steered to where it would be most effective, most likely to create a chain reaction, rain dropping out and reducing the average weight of the air mass so that it may rise around the falling raindrops? The batteries could allow this to work at night when condensation is also more likely. PS No need for a power station below. The Sun is a nuclear fusion plant already.
12/03/2024 12:51 PM
Load some artillery shells with fine crushed sand. Explode them over the top of clouds. Sprinkle some clouds with sand and see what happens.
For all we know, if we weren’t sprinkled with solar dust, we might not have rain at all.
Are rain seeds more than just structure? Maybe those seeds have a temperature too. Like that plate of steel.
Might even be the temp, not the structure that precipitates water. Small micro-scale temp.
There’s a lot we think we know, but maybe we just think we know.
From what I understand, a lot of rain seed dust flows from continent to continent. The Sahara not only feeds the S. and C. Americas, but a lot of Europe, Russia and middle east too. Most assume fertilizer effects. Only the smallest of particles makes the trip. The micro particles.
How many acres of crushed sand would it take to bring winds into the Sahara?
What could a cold spot do? Apply with caution. The heat loss is gone for good.
Good Answers: 16
12/04/2024 1:24 AM
I suspect that you'll also need the correct atmospheric conditions in terms of temperature, humidity, dew point, etc. The cooling tower has a guaranteed high humidity and, compared to the atmosphere higher up, a relatively narrow range of temperature and wind draughts/vertical speed. You may end up generating some drops a few thousand feet up - whether that will reach the ground in sufficient quantities is another matter. Cloud seeding requires suitable conditions, so this method will probably as well. To put it in perspective, to get a mere 10mm of rain on 1 hectare requires 100 000 litres (100m3), or ~900 million droplets of size 3mm. You're going to need one big electrostatic net!
12/04/2024 3:11 PM
The purpose of the original post was to recycle the already treated pure water back into the system saving makeup water, which has to be treated. This prevents concentration of acids, etc. in the makeup water, reducing maintenance and operation costs.
The cloud seeding off-shoot from this was my speculation that it might also work as a cloud seeder by generating opposite charges on water vapor causing them to cling together and eventually condense.
If a contrail forms behind a jet, there is moisture in the air. It is too high to fall as rain but it may get part of the way down to a lower level where conventional aircraft might be able to ionize it into bigger drops.
12/04/2024 3:23 PM
Better is a little bit of something than a whole lot of nothing.
Even a single candle is better than total darkness.
Who knows where a simple idea may lead.
The Wright brothers could not imagine jets, and look at what happened since a little over 100 years ago.
If I had a means to test it, I would.
I am merely suggesting that the principle be tested and further developed.
If it is profitable, it will be exploited and improved rapidly.
12/04/2024 3:25 PM
How 'bout many small nets pulled by many planes, or even kites?
Good Answers: 25
12/04/2024 4:22 PM
When talking about large geographical areas, I don't see how this could ever be feasible.
1" of rain over a state the size of California works out to about 2.8 trillion gallons.
Troy
12/04/2024 6:18 PM
For it to rain, you need feedstock such as dust for Nucleation to begin.
the space station did an experiment with salt, where attraction happened due to static electricity. From the OP. Even though it demonstrates planet building..l
12/04/2024 11:48 PM
Ion generators generate static electricity that can attract droplets to each other without a particle to build on.
Perhaps they could be used to dissipate fog in critical areas. Even the cheap for home usage ion generators can produce millions of ions per second. A Very small output, not suitable for such purposes.
A more powerful one can be built. If the ions are alternating in polarity at even 60 Hz that is a lot of ions and could attract a lot of water vapor molecules together. Adjust frequency according to velocity of the air flow around it.
01/24/2025 6:09 AM
Perhaps initially after the BB, static attraction was more powerful than gravity, but due to mass accumulation, it became a minor force compared to gravity. Consider the mass of a dust particle. When charged, it is more powerful than it's gravity.
Matter and anti matter, if the same charge, would repel each other and they would separate, which would perhaps explain why there is so little antimatter in our universe.
There may be another universe where antimatter is the norm, and our "normal" matter is their "anti" matter.
01/24/2025 11:40 AM
If you take a mathematical one dimensional line and twist it…. The result is a one dimensional line. No change.
If you take a one dimensional physical line and twist it………….. it results in a relative length, area and density. Plus…. plus…..a loaded acceleration. A potential acceleration. From one dimension. And if you close that line you get perpetual acceleration. The acceleration rotates. Forever. And if you add another twist, it will rotate faster. Absorption adds a twist and emission takes relaxes one.
Do you want to concept math…. Or concept physicality?
Would you like see an electron? An atomic dipole? Would you like to make some anti matter?
Do you want to here more?
Register to Reply 26 comments
Andy Frew (1); gideon (1); Haymaker (3); HiTekRedNek (11); Lehman57 (1); phoenix911 (4); PWSlack (2); Rixter (1); Stef (1); Troy36 (1)
