Previous in Forum: This is Basically a Plastiguage only Pb Wire. Pretty Cool!   Next in Forum: Breaking the Ice
The Importance of Glass
12/28/2024 4:58 PM
I found this very interesting, the history of glass, and the things it makes possible...I want unbreakable windows in my house someday...no more shutters, won't that be cool...
Re: The Importance of Glass
12/28/2024 8:51 PM
I guess the glass property I'm most impressed with is the transparency of the glass in optical fiber.
"For multimode fiber, the loss is about 3 dB per km for 850 nm sources, 1 dB per km for 1300 nm"
https://www.thefoa.org/tech/loss-est.htm
Imagine a window 1 kilometer thick with hardly any perceptible loss!
United States - Member - VT
12/29/2024 12:15 AM
If you are ever in the Southern Tier, the Corning Museum of Glass is worth a visit:
https://home.cmog.org/
Teach your cat to write
12/29/2024 1:53 AM
They mentioned that to make glass, it must be cooled rapidly so crystals don't have time to form. A number of complex alloys of metals mixed with some non-metals like silica, can be cooled at a rate as high as 2E6 F degrees per second from molten to near room temperature to form metallic glass.
This material is electrically conductive, like metal, but is relatively brittle, and has a very low coefficient of thermal expansion, like glass.
One of its uses is as a brazing material used to join parts that must withstand the temperatures inside jet engines.
12/29/2024 2:25 PM
As an example Harvester Silos (big blue silos which dominated the the United States farm skyline in the 70’s and 80’s) used that technology of glass fused to metal that initially started to store feedstuffs on farms.
At one time they did post how it’s made and it was interested. But now it’s limited.
12/29/2024 10:55 PM
Those silos use a totally different process: they are coating steel with glass. In the material I'm referring to, the metal itself IS glass (amorphous[non-crystaline]).
One source is https://metglas.com/company-products-and-services/.
12/29/2024 4:53 PM
Register to Reply 6 comments
dkwarner (2); jonaparker (1); phoenix911 (1); Rixter (1); SolarEagle (1)
