Previous in Forum: Memory Storage in a Sphere   Next in Forum: Splitting Water with Electricity and Ultrasound
LM50CIM3X for Temp Sensing
10/13/2025 5:03 PM
Hey everyone,
I’m pretty new to electronics and currently working on a small project, basically a simple power supply and battery monitor setup. I found LM50CIM3X, and it looks easy enough to use since it outputs analog voltage that changes with temperature. I was planning to mount it near a MOSFET or battery to track temperature and maybe shut things down if it gets too hot. But I’m still learning, so I wanted to ask:
Is this sensor good enough for accurate readings, or should I use something digital instead? Will the analog signal get messed up if there’s a lot of electrical noise? And does it respond quickly to temperature changes?
I’ve only done a few basic Arduino projects before, so this is a bit of a step up for me. I’d really appreciate any advice or real-world tips from you guys who’ve used the LM50CIM3X or similar sensors.
Thanks in advance! I’m trying to understand not just what works, but why it works.
Good Answers: 54
Re: LM50CIM3X for Temp Sensing
10/14/2025 10:55 PM
According to its datasheet, the LM50C has an accuracy of ±3 to ±4°C. If that's good enough for your purposes, then go ahead. If you need the best accuracy, the ADT720 has an accuracy of ±0.25°C, but it's more expensive.
So, you should first ask yourself, "What level of accuracy do I need?" Then go look for the sensor that satisfies your requirements.
You can use Google to search for "IC temperature sensors" or "semiconductor-based temperature sensors," to get a list. Then search for datasheets or application sheets to give you guidance on how to use them.
regards,
Vulcan
10/15/2025 8:45 AM
It should be fairly easy to filter out electrical noise with a 1 μf capacitor and a shielded twisted pair cable for remote sensing.
https://www.kasuo.com/pdf/?file=lm50.pdf&product=lm50cim3x-nopb-datasheet-price-pdf-2
