Previous in Forum: LM50CIM3X for Temp Sensing   Next in Forum: Where's the Beef (Leather)
Splitting Water with Electricity and Ultrasound
10/14/2025 11:25 AM
Would there be any benefit of using ultrasound together with electric current to split water into Hydrogen and Oxygen? Would the cavitation enhance the splitting effect, or not. Has this been tried?
Re: Splitting Water with Electricity and Utrasound
10/15/2025 1:49 AM
Don't know. You're the man HTRN, let us know how it turns out.
10/15/2025 2:55 AM
10/15/2025 8:14 AM
Apparently, ultrasound electrolysis increases hydrogen production; however, its energy efficiency is lower due to the energy required to generate the ultrasound.
https://ui.adsabs.harvard.edu/abs/2025ICHMT.16408980T/abstract
10/15/2025 12:01 PM
Ultrasound also produces heat, and have they tried to capture this waste heat to improve overall efficiency of the system?
10/15/2025 6:50 PM
I don't know what hertz you'd be running the Ultrasound at, you need to watch your cavitation so it doesn't tear up your ultrasonic horn like a prop would on a boat.
10/15/2025 8:41 PM
High heat is used in hydrogen production through methods like thermochemical water splitting and high-temperature steam electrolysis to split water molecules. These processes, which can use heat from concentrated solar power or advanced nuclear reactors, are often more efficient than low-temperature electrolysis. The heat enables the chemical reactions to occur at lower energy costs or with greater efficiency. Thermochemical water splitting
  • This process uses high temperatures (500°–2,000°C) to drive a series of chemical reactions that produce hydrogen and oxygen from water.
  • The high heat can be generated by concentrating sunlight with mirrors or from the waste heat of nuclear power reactions.
  • It is a potential pathway for low or no greenhouse gas emissions, as the chemicals are reused in a closed loop.
High-temperature steam electrolysis (HTSE)
  • This method splits water at elevated temperatures (800–1000°C), which accelerates the reaction kinetics and reduces the amount of electricity needed compared to low-temperature electrolysis.
  • HTSE can be paired with heat sources like advanced nuclear reactors to produce hydrogen efficiently.
  • It requires a heat source, electrodes, an electrolyte, and the electrolyzer membrane, along with a power source.
Using high heat yields the best efficiency...
10/20/2025 12:09 PM
Another idea is to drive the electrolysis with pulsing electricity, which would have a higher ratio of maximum field strength to average power.
https://www.sciencedirect.com/science/article/pii/S1364032125002576
Register to Reply 7 comments
HiTekRedNek (1); phoenix911 (1); Rixter (2); SolarEagle (1); StandardsGuy (1); The Wizard (1)
