Previous in Forum: Remote Control Lawnmower   Next in Forum: Part for Drain Tube
Bent Trees
03/30/2026 9:53 AM
I have a simple explanation for the crooked forest. I had some drums on my wooded property, lying on their side, and pine saplings started growing from under the bottom edge. They followed the curve of the drum until they were tall enough to grow straight. They looked just like the ones in the crooked forest.
It is possible that drums were stored on the property and removed before they were fully grown, but still crooked as a sapling.
Looking at the drums, they look too perfectly bent to be a virus or storm damage, like the were bent on a mandrel(or drum).
Some could have sprouted after the property was mowed or broken off when the drums were dumped there, because it looks like the roots are going straight down from cut off or broken stump.
I wonder if anyone has tried to pull a string from 2 adjacent trees to see if they form a straight line or have the same diameter? A long, total view might be able to determine the drum placement by looking at the group as a whole and fitting cylinder shape to the image.
Comments welcome as always,(even pedantic ones(I'm over that peeve )
https://en.wikipedia.org/wiki/Crooked_Forest
Pathfinder Tags: bent trees
Re: Bent Trees
03/30/2026 11:08 PM
The natives here in America did this to trees to point in various directions as signposts. I imagine these were bent as saplings toward north in much the same way and for much the same reasons. It doesn't hurt the trees and as living trees they just keep pointing for as long as they live. Signposts that don't decay.
Re: Bent Trees
03/31/2026 3:27 AM
Re Deefburger's comment about native Indians and using Trees as signposts reminds me of another Indian using wood as a sign.
A Settler moves on to a piece of land in the Wild West and builds a Log Cabin, As he builds it an old Indian walks by and says "you should be finished by autumn" to the cowboy.
Sure enough Autumn comes around and the cabin is finished. Cowboy then thinks I'll need wood for the fire.. so he chops a pile of wood.. Old Indian walks by, looks at the firewood and says " Cold Winder coming".
The cowboy chops more wood, Old Indian walks by, looks at the firewood and says "very cold winter coming"
Once again the cowboy chops a load more wood. Old Indian walks by, says " A very cold and long winter coming" !
The cowboy asked the Old Indian, "Hey how do you know its going to be a very long and very cold winter "?
Old Indian looks at the huge pile of Firewood and says " I see how much wood you are cutting" !
Good Answers: 25
Re: Bent Trees
03/31/2026 9:45 AM
One of the theories out there is that furniture makers from the area may have done it intentionally, experimenting with trees to get wood with curved grain. I'm not sure if it has any merit.
Troy
Good Answers: 80
Re: Bent Trees
04/27/2026 7:40 AM
That was my thought as well for furniture or boats.
Re: Bent Trees
03/31/2026 10:36 AM
It has been common practice to cut naturally bent wood for boat frames as opposed to steam bent frames. I imagine furniture makers could do the same thing.
Good Answers: 204
Re: Bent Trees
03/31/2026 2:23 PM
Grow, grow, grow your boat, gently down the stream....
Re: Bent Trees
04/27/2026 4:26 AM
Maybe the saplings sprouted under a fallen log?
Register to Reply 7 comments
chrisg288 (1); DaveD (1); Deefburger (2); marcot (1); The Wizard (1); Troy36 (1)
