Previous in Forum: Shell Distortion FFS: How Nonlinear FEA Resolves Code Ambiguity for Out-of-Round Vessels   Next in Forum: Joining this Professional Forum
At What Stage Are Most Product Reliability Problems Introduced?
06/17/2026 2:52 PM
I've worked on projects where products passed functional testing during production but still experienced reliability issues later in the field.
In your experience, at what stage are most reliability problems introduced?
* System architecture
* Component selection
* PCB layout and signal integrity
* Thermal design
* Manufacturing processes
* Supplier quality
* Validation and testing
Many organizations focus heavily on manufacturing quality, but I've seen cases where issues could be traced back to earlier engineering decisions that weren't obvious during development.
For those involved in electronics, semiconductors, or PCB-based products, which phase has the biggest impact on long-term reliability, and why?
I'd be interested in hearing real-world examples and lessons learned.
Good Answers: 27
Re: At What Stage Are Most Product Reliability Problems Introduced?
06/18/2026 8:56 AM
Initially the theoretical design aspects of the design are used in combination with the weakest or lowest technical component specifications as reference to be used prior to the production of the prototype samples for the supposed product..
The prototype production is followed by a series of functional and quality performance process where the final testing results and evaluations are combined and subjected to a following of simulated environmental performance application processes..
In practice This pass/failure testing stages of the final QA processes of the prototype product is where the combined product reliability is determined and established.... And which are incorporated prior to the manufacturing the final product..
vsar
06/18/2026 2:07 PM
I agree that prototype validation and environmental stress testing are critical stages for establishing confidence in product reliability. However, from my experience with electronic systems, I've found that many reliability issues are effectively "designed in" long before the prototype is built.
For example, component derating, thermal margins, signal integrity, power integrity, PCB stack-up decisions, and supply chain component selection can significantly influence long-term reliability outcomes. In many cases, qualification testing doesn't establish reliability; it verifies that the design and manufacturing processes have met the intended reliability targets.
This raises an interesting question: do you think the industry relies too heavily on pass/fail prototype testing, rather than incorporating reliability engineering principles earlier in the design and component selection process?
I'd be interested in hearing how others balance design-for-reliability practices with prototype qualification and environmental testing.
Good Answers: 27
06/18/2026 5:35 PM
You may have missed to read the 1st paragraph in my response.. This is where the quality, function and integrity of each every components you used are determined
Which means that your component selection processes is relying on the corresponding QA of whoever manufactured those selected components..
Which also means that the functionality, quality and reliability of your chosen product will mostly be dependent upon your knowledge, experience and technical ability to apply and implement your goals and objectives..
vsar
06/19/2026 7:41 AM
Sorry, my bad, I think you've highlighted an important point regarding component selection and the engineer's responsibility in applying those components correctly.
One aspect I'd add is that some reliability issues only become visible after products accumulate significant operating hours in the field. Accelerated testing and qualification can identify many failure modes, but they don't always capture every real-world operating condition or use case.
This is why industries such as aerospace, automotive, and semiconductor manufacturing place so much emphasis on field-return analysis, reliability growth programs, and continuous feedback into the design process. In many cases, the most valuable reliability data comes not from the prototype stage, but from understanding why products fail after deployment.
Would you say that long-term field performance data is ultimately a more accurate measure of product reliability than prototype qualification testing alone?
08/08/2026 2:17 AM
There are limits to how many tests and checks can be done prior to shipping, and these are done under ‘as new’ conditions, even if humidity, temperature and pressure are all altered in an array of tests.
The real use data is the most important as that shows how the products are actually used which can differ significantly from the design intent.
Even where items are used outwith the stated parameters, improvements can be made to minimise issues in the field for the next generation of device.
A lot of mobile devices have become water resistant due to the numbers of customers getting them wet accidentally. Not something the original design had taken into account.
Madness is all in the mind
Ahmad Faraz (2); GM1964 (1); vsar (2)
