Previous in Forum: Gas Detection   Next in Forum: Challenges in Industrial Instrument Calibration and Long-Term Stability in Harsh Environments
Electromagnetic vs Ultrasonic Flowmeter: When to Use Which?
08/20/2026 11:32 PM
Electromagnetic vs ultrasonic flowmeters is a common comparison when selecting a flow measurement technology for industrial liquid applications. Both technologies can provide accurate, non-mechanical flow measurement, but they use fundamentally different measurement principles and have different application requirements.
The queston is:How to Choose ?
Instruments and Sensor Engineer
Re: Electromagnetic vs Ultrasonic Flowmeter: When to Use Which?
08/21/2026 12:38 AM
There are some fluids that are not suitable for an electromagnetic flow meter.
There are some piping installations that are not suitable for ultrasonic Doppler flow measurements, or for that matter, for magnetic flow meters.
There are many other flow measurement technologies that are much less expensive with varying degrees of accuracy.
Flow Measurement Engineering Handbook by Richard W. Miller gives you a logical method to select suitable methods to measure your fluid.
Good Answers: 54
08/26/2026 10:47 PM
The main consideration for using electro-magnetic flowmeters (AKA magflow) is the conductivity of the fluid. If it has poor conductivity, magflow is not a choice. The pipe also needs to be completely filled. Magflow, however, has less stringent requirements for upstream and downstream piping and is more forgiving of having sediments or particulates in the fluid stream.
Some ultrasonic flowmeters need particles in the fluid that it can create the Doppler effect. More advanced ultrasonics are able to measure flow with clean fluids so be sure to read the documentation before purchasing. Ultrasonic signals are also affected by temperature so choose an instrument with temperature compensation.
If your process fluid creates coating on the walls of pipes, magflow that have teflon linings are better able to handle these situations. A teflon lined pipe (at the time when I was still working) is not suitable for ultrasonic flowmeters.
I don't usually rely on general comparisons, however. I read the technical documentation from the manufacturers or talk to one of their engineers to get information.
regards,
Vulcan
Register to Reply 2 comments
