Previous in Forum: Electromagnetic vs Ultrasonic Flowmeter: When to Use Which?
Challenges in Industrial Instrument Calibration and Long-Term Stability in Harsh Environments
08/25/2026 10:45 PM
Hello CR4 Community,
In modern industrial processes, we heavily rely on high-precision instruments (such as flow meters, pressure transmitters, and temperature sensors) to maintain safety, efficiency, and product quality. However, maintaining long-term measurement accuracy under harsh environments—such as extreme temperatures, high vibrations, and corrosive media—remains a major engineering challenge.
I would like to open a discussion on how different industries and engineering teams handle these issues:
  1. Drift and Calibration Interval: How frequently do you calibrate your critical instruments? Have you experienced unexpected drift caused by environmental aging, and what methods do you use to mitigate it?
  2. Harsh Environment Protection: For instruments deployed in extreme conditions (e.g., offshore platforms or high-temperature chemical reactors), what specific material selections or protective enclosures have proven most reliable?
  3. Smart Diagnostics: With the rise of IIoT (Industrial IoT) and smart field devices, are you utilizing predictive maintenance or remote diagnostic features to catch instrument failures before they lead to downtime?
I look forward to hearing your practical experiences, field insights, and best practices regarding industrial instrumentation management.
Best regards,
Instruments and Sensor Engineer
Good Answers: 54
Re: Challenges in Industrial Instrument Calibration and Long-Term Stability in Harsh Environments
08/26/2026 10:32 PM
Back when I was still working in a factory, we had a calibration interval chart that we used to determine initial calibration intervals. It had several criteria to determine the interval:
  • environment - class A, B, and C. A was harsh (like very hot) conditions; B was medium (like warm) conditions; and C was non-harsh (like ambient outside air) conditions.
  • purpose - class A, B, and C. A was safety purpose; B was control; and C was for monitoring.
  • utilization - class A, B, and C. A was continuous (24/7/365) use; B was 2/3 use (up to 9 months per year); and C was 1/3 use (up to 4 months per year).
Then we made a chart that had intervals in multiples of 3 months. For example: if an instrument was AAA, the interval was 3 months; if the instrument was AAB, the interval was 6 months; if it was AAC, the interval was 9 months.
The result was a chart that allowed us to make a calibration interval for the instrument. The maximum interval was 24 months (for test weights).
There was a lot of discussion before we came up with a chart that satisfied everyone. Some wanted the environment classification to have a fixed interval of 3 months if it was Class A, meaning it didn't matter if it was a Class ACC (harsh environment, monitoring, and used for only ≤4 months per year), it should still be 3 months interval.
These intervals were only initial, however. After several calibrations, we would have a record of the calibration drift and we could increase or decrease the interval based on how fast it was drifting. Of course, we needed to establish the tolerance for each instrument that would trigger a change in the interval.
Regarding selection of materials, we had materials guidelines. If the environment was, say, water, we could use this material. If it was acidic (also depends on the type of acid), we use a different material. Sometimes, we consulted with the manufacturer.
Smart diagnostics? By the time I left, smart diagnostics just started to appear in instruments and they were very simple. A parameter would just say that the instrument was near failure and needed replacing. I haven't been keeping up to date so I don't know how capable they are these days. I usually relied on process readings. For example: a particular control valve position is usually 50% to achieve, say, 150°C. Over time, it became 70% to achieve the same position. That tells me it's time to check the valve, the positioner, or the process (yes, sometimes, it's the process' fault).
regards,
Vulcan
08/27/2026 9:56 PM
In small pulp & paper operations, instrument calibration was done most often when other indications dictated that something was wrong. Many processes have enough monitoring and cross-checking so that one instrument failure can be detected by other readings or statistics that don’t match. It is a very reactionary environment that often leads to some product loss or increased manufacturing costs.
In some 40 plus practical years in instrument application, closely following the recommendations of the instrument manufacturer has proven most successful in a achieving a long term economical solution. This, of course, requires a competent engineer or staff with complete knowledge of the process conditions, operation, cleaning and maintenance.
Purchasing high quality smart instruments has significantly reduced the cost to operate paper mill processes. Recalibration of a pressure or flow transmitter that was correctly installed is rarely necessary. It either works correctly or it fails to the point it is unusable, and readily detectable.
09/10/2026 6:07 AM
<...indications...something was wrong...>
That's reactive, not an assurance of on-spec product all the time, of course.
09/12/2026 9:09 PM
Yes, wasteful. Typically prompt enough to minimize bad product in this continuous process, and contain it. In pulp & paper, maybe 70% of bad product industry wide can be recycled into the process, so the losses can appear to be tolerable.
Register to Reply 4 comments
PWSlack (1); rwilliams (2); Vulcan (1)
