Previous in Forum: Vibration Motor AC DC   Next in Forum: Standard Centrifuge Tube Size
10 comments
Dimensions of Flange and Gusset
12/13/2007 6:35 AM
I want to know the following:
a) dimensions of 800 mm NB Flange as per ANSI B 16.5 class # 150
( O.D., PCD, Thickness, Hole Dia, No. of Holes, RFD)
b) Dimensions for Bellow of Size 800 mm NB
( Gusset Dimensions )
Re: Dimensions of Flange and Gusset
12/13/2007 11:44 AM
Contact any reputable flange and fitting supplier, they should be able to supply the information, failing that you can go to www.techstreet.com and from there you can purchase the standard in question, either hard copy of PDF download.
Vote for something useful this time, vote to repeal the second law of thermodynamics!
12/14/2007 10:44 AM
Kev: Checked out your flange data download. Absolutelutely the best item I've found on flange data to date.
Thx for sharing
"A job worth doing, is worth doing well" - My Father
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
12/14/2007 10:48 AM
No problem at all - happy to help out fellow engineers in any way I can.
12/15/2007 11:15 PM
Hi, Kev Brown,
Thank you for your reply.
I wanted to know the specified values of the following:
for 800mm NB Flange, a) O.D., b) PCD, c) Thickness, d) Hole Dia., e) No of Holes
following ANSI B 16.5 Class # 150 specs.
And also measurements of GUSSET for the same size.
Best Regards,
Kusari
12/16/2007 1:09 AM
Once again, Flange 800 DN (not 800 mm NB) is the same as 32 NPS and is governed by ASME B16.47 not by ASME B16.5, please refer to posts 6 & 7.
What do you mean with gusset? Do you mean gaskets?
12/15/2007 11:23 AM
DEAR SIR
PLEASE NOTE, ASME B16.5 COVERS FROM 1/2" (15MM) TO 24"(600MM) ONLY. FOR SIZES ABOVE 24" UP TO 48" REFER ASME B 16.47 OR MSS SP44.
THANK YOU
V.D.DEODHAR.
12/16/2007 6:41 AM
Dear Mr. Deodhar,
Thank you for the reply.
Got the dimensions from B 16.47. Thank you sir.
Can you get me the dimension for Steel GUSSET to be used with these flanges ? Actually we are designing an flexible expansion bellow(rubber expansion joint) but could not find these dimensions.
Best regards,
Kusari.
12/15/2007 3:07 PM
Dear Kusari
ASME B16.5 : Pipe Flanges & Flanged Fittings NPS 1/2" Through 24", where
ASME B16.47 : Larger Diameter Steel Flanges NPS 26" Through 60".
The required dimensions of flanges size 800 mm (NPS 32") 150# are located at ASME B16.47 as follows :
OD 41.75"
BCD 38.5"
Thk. 3.19"
Hole Dia. 1.62"
No. of Holes 28
RFD 36"
Taking into consideration that 1" = 25.4 mm
12/09/2009 2:29 AM
dimensions of 800 nb flang as per ANSI B 16.9 CLASS 150# A SIRIES
01/21/2011 6:10 AM
Please note, ANSI B16.5 Class-150 is the specification of flanges NB1/2" to 24" and above sizes up to 60" is as per ANSI B16.47B #150. Hence note down the flange dimension of 800mm as per ANSI B16.47B #150, as under:
Size: 800mm O.D.-941.32mm, Thickness-44.45mm + 1.6mm Raised Face, Raised Face Dia - 863.6mm, PCD-900.18mm, , Hole Dia-22.35mm, No. of Holes- 48 Nos.
Thanks,
Ashis Paul
Register to Reply 10 comments
Abdel Halim Galala (2); Anonymous Poster (2); Kev_brown (1); kusari (2); silver ghost (1); vidyadhar deodhar (1); Zaphod2Headed (1)
