Brad writes:
I am looking to buy or make an anemometer that provides the wind speed and direction display ~ 750' from the actual sensor unit. I have found to purchase a unit that will work is ~$1,600, but that is far out of the budget. The system I would buy uses 750' of Cat 5 type cable between the sensor and the display unit. This does not seem complicated enough to make up the cost difference over a regular close range weather station that retails for a couple hundred dollars. Any ideas?
