Previous in Forum: Your Website   Next in Forum: SHEET METAL (CU,PB ,BRASS)
Gasket Made Out of Mixing Two Liquids For Panel Enclosure
12/20/2007 2:45 AM
i am searching for a gasket which is made by mixing two chemicals. the materials are injected from the nozel on the sheet metal door & it foam joint less gasket to give enlosur a dust free protection. Can any one help by suggesting the name of the materials, the machine used for this gasket.
Re: gasket made out of mixing of two liquid for panel enclosure
12/20/2007 6:22 AM
It looks like a proprietary enclosure from the photograph. What's wrong with contacting the original equipment manufacturer for them to supply some replacement gasket material?
12/20/2007 8:08 AM
If I'm not mistaken I've come across this stuff used for automotive panels etc... I think it is a form of isocynate mix that is placed along the edge and then it foams up and solidifies...
Something like polyurathane foam I guess?
Most car parts use this sort of sealing stuff a two part mix applied usually by machine with extremely good ventilation...
Sorry that's about all I know of it - John.
Re: Gasket Made Out of Mixing Two Liquids For Panel Enclosure
12/21/2007 3:24 AM
Hi,
You mean FIPG (Form-in-Place-Gasket), used in place of the conventional gasket.
I use one but for Hard Drive Cover. Its from 3M. Maybe u can check with them if they can suggest what material to use for your application.
12/21/2007 3:32 AM
http://acc-silicones.com/
you can check this out.
Register to Reply 4 comments
Electroman (1); PWSlack (1); yvi (2)
