Previous in Forum: Overflowing Fuel Oil In Transmitter   Next in Forum: Butterfly Valves
Square Edge Orifice Meter
12/20/2007 7:00 AM
is it possible to use Square edge orifice plate for bi directional gas flow measure?
Re: Square edge orifice meter
12/20/2007 7:20 AM
Yes
Good Answers: 15
12/20/2007 7:54 AM
What type of accuracy are you after? What is the flow rate?
The more info you can give about the use the better answers you will get.
downhill slide to 112 (damn memor.)
12/20/2007 8:04 AM
the flow rate is between 60 - 70K SM3/D for import and flow of 100K for export. accurcey of .02.
12/20/2007 8:42 AM
.........so the differential pressure cell fitted across the orifice simply needs to be calibrated for the greater of those two flow ranges at the pressure in the line. Apart from ensuring that the upstream and downstream pressure taps are a mirror image of each other about the plate, and there are sufficient pipe diameters up- and down-stream, what's the problem <rhetorical question>?
Remember that differential pressure is related to flowrate via the square root function!
12/20/2007 12:04 PM
if I use portable panameteric meter to verify the actual flow with orifice do you think the reading will be same if not why
Re: Square Edge Orifice Meter
12/20/2007 2:13 PM
The meter can be recalculated and a meter correction factor used to compensate for the non beveled edges, but that will take a laboratory set up. You'll also have problems with upstream lenght and postions of the temperature transmitters.
Ultrasonic can be set up bi-directional. You can install 4 DDB valves and make it a true API/ISO meter run. Or just install two tubes, one for each direction.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
12/21/2007 9:30 AM
Watch out for the beveled edge on your orifice plate...
I can't think of something more frustrating than getting flow meters to measure the same, especially orifice meters. Are you pressure and temperature compensating the meters? Maybe take a 5 minute average of each meter and see how close they are to each other. There are a lot of variables going into your measurement.
I notice that you are reporting in Sm^3/D, do you reliably know the density of the material as well?
If I had a choice, I would go with 2 meter runs as it has the least potential for trouble.
Money doesn't talk, it screams in your face.
Anonymous Poster (2); betomachine (1); ddk (1); PWSlack (2); vicini (1)
You might be interested in: Edge Trims and Trim Seals, 3G, UMTS and EDGE Chips
