Hello all you Brilliant Minded People,
I envy anyone who has the patience to figure out these details in low voltage design...
I have more patience with High Voltage, than Low Voltage, (at least I know what the result of high voltage will do).
Anyway, now to the problem, and question:
We have a simple electric/electronic PCB, basically single side, with the exception of a single 3-position toggle switch on the back side.
This board is an incandescent dimmer, using common Triac design.
Because my EE has been called back to the Iraq war, I am forced to figure this out myself, (Which I feel very lacking in experience, and patience).
We are attempting to convert basically an analog Potentiometer, so that we can still use the pot, but also have a digital LED readout to display the setting of the pot into characters from 0-99.
My apprentice friend used his Radio Shack Kit and came up with a board that almost accomplishes this goal.
Our problem is, as we turn the pots knob, the separation between the numbers is SO close, that it's hard to keep it on one display number, so flickering between numbers is the distracting problem. We can make it stop, but you have to be exact...
My question is:
How can we still use this rotary POT, but make the board with a little more separation between the numbers so as to avoid that annoying flicker if you don't get it set just perfect.
I know we could avoid all of this by just switching over to to normal push type digital, and we may have to do this eventually, but then our design must change and much more is involved..
Please guys, in the Spirit of Christmas, is there any way we can remedy this, using our old design with the manual POT ?
Sincerely,
Frustrated in Arkansas,
Donald
