ad I work on a high pressure leaching plant which treats an alloy of Cu-Co-Fe ( about 5%, 12% and 75% respectively) that is a product of a smelter located on the same plant. The molten discharge from the furnace is atomised into granules of about 60 % passing 150 microns. This is then pumped to the leaching section. The problem that exists now, or indeed for the last 7 years is the accouting of the alloy sent from the atomiser, tonnage wise, ( which is part of the smelter) to the leaching plant. These two departments been separate must account for the output from the smelter and the input to the leach plant.
The alloy has an SG of 7000 and is pumped at a rate of about 100m3/hr at a density of between 1030 and 1070. The problem has been to find ( if it does exist) a flowmeter or measuring device that would accurately measure the flow of this type of material taking into consideration the the diverse parameter of the SG, flow, density, fineness and abrasiveness of the alloy! This will help to calculate the tonnage produced. If there is another way of doing it but arriving at some accurate figure, please help!
