Previous in Forum: Building Load Calculations   Next in Forum: Switch With 2 Function Parallel
11 comments
Capacitor
12/31/2007 1:51 AM
why a capacitor destroys by changing polarity in a circuit
means negative terminal to positive and +ve to -ve
Re: capacitor
12/31/2007 7:53 AM
Polaraized capacotors typically have very low reverse breakdown voltage. If they are reverse biased they will allow too much current to flow, the heat up and typically leak or pop depending on the capacitor type, size and current flow. Some capacitors will not suffer permanent damage if the current is limited to a very low value. Non-polarized capacitors can be biased in either polarity without being damaged.
Re: Capacitor
12/31/2007 3:05 PM
too much heat/energy to be handled, the same theory as a bomb.
Funny N.
Re: Capacitor
01/01/2008 11:00 AM
a simple search would have found this
Reverse Voltage care:
Electrolytic capacitors generally have a positive and a negative terminal. As we said earlier, the plates (foil) of the capacitor are anodized with a DC current. This anodizing process sets up the polarity of the plate material (it determines which side of the plate is positive and which is negative). We also said that part of the electrolyte was to help heal a damaged plate. Since it has the properties to heal a damaged plate, it has the ability to re-anodize the plate. Since anodizing process can be reversed, the electrolyte has the ability to remove the oxide coating from the foil. This would happen if the capacitor was connected with reverse polarity. Since the electrolyte can conduct electricity, if the aluminum oxide layer is removed, the capacitor would readily pass direct current from one plate to the other (it would basically be a short circuit from one plate to the other). This would, of course, render the cap useless.
Out Of The Inner Circle
Re: Capacitor
01/02/2008 5:37 AM
An electrolytic capacitor incorrectly biased goes very quickly, because it is not designed to be used that way. There is a significant risk of personal injury (been there, got the T-shirt, etc.) so DON'T DO IT!
Re: Capacitor
01/02/2008 2:14 PM
Hi PW, Your illustration is worth the hundred or so words I would have chosen to relay the same information. Very clever. TK
intellectuals solve problems, geniuses prevent them ~ Einstein
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Capacitor
01/03/2008 9:40 AM
Anybody wanna buy some capacitors? Just fallen off the back of a Space Shuttle....<Cough, splutter>
Essex jobs for Essex yobs! <Burp>.
Re: Capacitor
01/04/2008 8:14 PM
A polarized capacitor is a chemical junction with high electrical resistance to one direction and low resistance to the other. same as a semi-conductor. when electrons flow from low to high, current is low, and vise versa, current is high when flows from high to low.
So, when current flow through low resistance Power dissipation is high. You can now make your own conclusions.
Wangito.
Never trade luck for skill.
Popular Science - Cosmology - New Member United States - Member - New Member
Re: Capacitor
01/04/2008 8:21 PM
So, in effect, we could essentially use an unpolarized capacitor along with a diode in series. IOW we just combine the two, right?
All worthwhile programmers know that constants always vary.
Re: Capacitor
01/05/2008 6:04 AM
JohnJohn,
Consider the level of the answer in accordance with the level of the question...
I probably should have added that we deal with electrolytics, and DC only...
Wangito.
Re: Capacitor
01/08/2008 2:56 PM
That (#8) was a BIG FAT tongue-in cheek response wangito.
Good Answers: 11
Re: Capacitor
01/07/2008 7:53 PM
Er no!
Emjay4119 (1); FunnyNYPD (1); Hap (1); Johnjohn (2); PLM NY (1); PWSlack (1); Stinky Pete (1); taejonkwando (1); wangito (2)
