Previous in Forum: different differential gains   Next in Forum: Flux Production In The Relay By DC Voltage
Harmonics
01/01/2008 11:37 PM
what is the maximum total current harmonics in % can be pumpback to the grid power supply if iam using the power supply it switch @higher than 100 khz but it generate the the harmonics from 3rd (fundematlal frequency-50 hz)up to the switching frequeny
Re: harmonics
01/02/2008 12:13 AM
Hi,
You can use IEEE std 519-1992, IEEE Recommended Practices and Requirements for Harmonic Control in Electrical Power Systems. Table 10.3 presents the current distortion limits for general distribution systems (120 V Through 69 000 V).
Re: harmonics
01/02/2008 8:12 AM
Local guideline also may be referred.
BNDas
Good Answers: 120
Re: harmonics
01/02/2008 10:42 PM
low pass filter can block some of these.
Power company may well charge you extra for shoving this onto their line
Per Ardua Ad Astra
Re: Harmonics
01/03/2008 8:38 PM
TAKING IN 50Hz And trying to pump back 100Khz?
Do not be a polluter-radiating all over the El Mag spectrum through the grid lines!
Have a low-pass(onto you-) filter through which you draw in50~( and which blocks YOUR pollution)
The 100KHz is no good for man or beast.
Anyway- how many KW OF 100 KHz can you pump out?
Anonymous Poster (1); aurizon (1); biswanath.das (1); MUKULMAHANT (1)
