Previous in Forum: Harmonics   Next in Forum: Why A Capacitor Is Used In Series of an Ordinary Fan
Flux Production In The Relay By DC Voltage
01/02/2008 5:29 AM
how flux produces in the energising coil of the relay by a dc voltage where AS ''flux produces in a coil by AC''
Re: flux production in the relay by dc voltage
01/02/2008 5:32 AM
Magnetic flux is proportional to current, and to the number of turns of wire in the coil.
Good Answers: 18
Re: Flux Production In The Relay By DC Voltage
01/02/2008 9:16 AM
Magnetic flux is in one direction only in a DC coil. That is, North or South, in common terms, depending upon which direction the current flows in the coil.
In AC coils, the flux changes with the alternating current. That is, if you have 50 Hz power, the flux changes from one direction to the other (N and S) 50 times per second.
01/02/2008 11:36 PM
flux production in a coil is due to the varing current but in the case of dc relay why dc produces magnetic field in the relay coil
Good Answers: 18
01/03/2008 9:12 AM
I think the problem lies with your definition of "flux." Flux, in the general sense, means "flowing." Magnetic flux, on the other hand, is a quantity. Magnetic flux density is a measure of magnetic field strength.
Good Answers: 143
01/03/2008 9:30 AM
The magnetic field in an ac coil is not due to varying current but just current. A steady current produces a steady field; a varying current produces a varying field.
Look at Hyperphysics and go to Electricity and Magnetism.
Bill (2); PWSlack (1); tauqeer (1); TVP45 (1)
