About 20 years ago I left the Royal Navy. Trained in weapons engineering I set about finding a similar field. I looked carefully at alternative energy and found that it was still in its infancy. My career took me down a different path, however it didn't stop me thinking. Recently the birth of my son has given me some time to look again at the marketplace and products available, I came to the conclusion that wind turbine design in particular had significant room for improvement . These are my ideas on how wind may be harvested more efficiently. My terminology may not be correct but I hope you get the Idea.
Maximize blade potential, minimize torque, remove mast mounted electrical generation.
The obvious design difference with this turbine to all others is it contra rotational turbine design. (as used by the Kamov helicopter company) This has a front turbine turning clockwise while the rear turbine turns anti clockwise cancelling torque and providing almost twice the power from the same diameter of rotor. Power from the turbine is transmitted via a simple spider gear (ie one cog on each shaft each turning a single cog on a vertical shaft housed within the vertical support) The net result being a shaft turning at ground level. braking and a hydraulic device for keeping the turbine into the wind is then fitted as is a hydraulic pump and reservoir. That is it! one unit. This design removes all electrical components generators, slip rings and cabling from the structure while increasing efficiency of blades, removing generator noise, and completely removing the need for electrical maintenance or servicing on mast.
Hydraulic system.
Whether on shore or offshore our hydraulic pump turns producing hydraulic pressure through super smooth low permeating pipes using oil, Etheline glycol or water to our generation station Many inputs may be received at the generation station all of which will be directed to a bank of Hydro-pneumatic accumulators ( These are pressure vessels which contain a bag filled with a nitrogen pre-charge a one end and a fluid port at the other end. These do two jobs, smooth out irregular hydraulic pulses and store hydraulic energy) Input may also come from other sources at the accumulator other than turbines, wave power tidal power or a diesel engine for example.When the accumulators are charged they are capable of discharging at a steady rate and are able to produce high quality, high EMF, AC energy. Through a hydraulic motor connected to a generator.
This system would not only produce energy cheaper through lower installation and maintenance costs it is easy to integrate with other systems and can be used on a large or small scale. It would still require the wind to blow in order to charge the system and maintain pressure unless of course there were other inputs able to fill in the gaps in wind.
I doubt that much would be patentable as each component is in use in other fields and I think that Its better to get the idea out there than bottle it up.
So what do you all think? anyone see any holes?
