Previous in Forum: Indian appliance in US   Next in Forum: Metal Gauge Design on Rectangular Membrane
drive for 48vdc servo motor
01/05/2008 6:53 PM
i am in surch of analog or digital drive for the 48vdc servomotor it detail as follow
DC SERVO MOTOR
POWER:- 180W
INPUT VOLTAGE:- 230VAC 50Hz
OUTPUT VOLTAGE:- O TO 48VDC
RPM:-3000
TECHO OUTPUT:- 7V PER 1000RPM
PLASE SUJJEST COST EFFECTIVE SOLUTION FOR THIS ITEAM
Re: drive for 48vdc servo motor
01/06/2008 10:56 PM
We can help you with such a supply.
Silacon............ Technologies that change the world
01/07/2008 8:55 AM
That's a standard drive that anyone can help you with. Since you require 3000 RPM, and your KE is 48 volts, you may get this on 110 volt AC drive. The buss voltage on the drive will be rectified to around 155 VDC meaning that your motor can run 155/48 or 3229 RPM.
Accounting for fluctuations in AC of -10%, your motor can safely run the 3000 RPM.
A 7V tach is stadard also.
If you let me know your location via email to awilliams@machineautomationproducts.net
I will get you a contact in your state who may be able to help.
Good luck.
01/07/2008 10:37 AM
Try www.parallax.com They have a great variety of both software and hardware tools very usefull to work with servo motors. They are also very reasonable with prices.
