Previous in Forum: oscilloscope   Next in Forum: About Frequency Drive
trigger
01/07/2008 12:14 AM
hello!
i want to understand the phenomenon of trigger
Good Answers: 230
Re: trigger
01/07/2008 12:47 AM
Hello tauqeer,
Read about Trigger here:
http://www.imdb.com/name/nm1022326/bio
You could also know that a trigger in the mechanical field is a mechanism to allow at a certain time, the operation of large force with the trigger being a small-force initiator.
Thus in a firearm, the trigger allows a spring to operate a small set of levers and pin, to strike a cartridge case, which detonates the primer in the cartridge case, which in turn, detonates the main charge, to explode the gunpowder, which rapidly propels a bullet out a barrel.
So....you have asked in the CR4 Electrical engineering Forum, and the simple answer is that a trigger is a small sudden force, current, Voltage, or electrical discharge, which initiates a much larger instantaneous force, current, Voltage, or electrical discharge.
If you need more information........
Re: trigger
01/07/2008 8:01 AM
The label trigger can be used to describe any event that initiates another event, it can also used to describe a mechanical device used to initiate an event.
Ask a simple question, expect a simple answer
Good Answers: 143
Re: trigger
01/07/2008 8:39 AM
Leonard Slye kept Trigger.
Good Answers: 266
Re: trigger
01/07/2008 5:48 PM
No phenomenon about him he's stuffed
Register to Reply 4 comments
ozzb (1); PLM NY (1); Sparkstation (1); TVP45 (1)
