Previous in Forum: Natural Gas Versus Diesel Engines   Next in Forum: Heat Exchangers with Fined Tubes
8 comments
Compressor Selection
04/06/2006 7:07 AM
Sheikh writes:
We are considering putting up a boosting station for compressing natural gas from 30 to 55 bar. We want to combine high efficiency of gas engine driver with high reliability of centrifugal compressor. Is it a relatively uncommon combination of compressor and driver type? Any input?
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
compressor selection
04/06/2006 11:41 PM
You should not have any problem for selection of gas engine for your centerifugal compressor contact aplication engineer of either Caterpillar or Cummins engine dealer nearest to you with all nessery inputs on your compressor like HP Drawn by compressor Tarque deatils of the compressor duty cycle of the compressor,Number of Hours of operation of the compressor per day,Chemical composition of fuel gas avilable ETC Provide as much information as you can on the compresor
Run silent run deep
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Re:compressor selection
04/07/2006 1:56 AM
This can be further confirmed,if we get feedback from someone who has already made use of such application. We can learn from past experience rather than having to reinvent the wheel.
nvmani
04/07/2006 4:52 AM
i was an application engineer for one of the largest engine manafacturer in the world and its quite comon to couple centrifugal compressors for airconditioning applications.So if you have all techenical information on your Compressor.each application has to be studied in deatil and select the primemover.
Run silent run deep
04/07/2006 7:51 AM
Thank you for the information. What about fuel preference for primemover,from efficiency considerations?
nvmani
04/07/2006 11:36 PM
Concidering the cost of avilable fuels like HSD,HFO etc and emission issues with these engines its advisible to choose Gas engines provided you have an assured supply of Gasues fuel.I dont know where you are located Number of Power plants are running on Gas engines in and arround Delhi.Gujarath etc.Who are operating Gas compressors driven by gas engines.
Run silent run deep
gas compressor
04/07/2006 9:37 AM
Try FES Systems of York, PA. They build screw compressor gas drive packages for the gas distribution industry. I've used their equipment in the past and have had very good results. Gary Wessel
I love NH3
compressor comment
04/09/2006 2:37 PM
check out:http://www.rolls-royce.com/energy/products/oil gas/default.jsp
Re: Compressor Selection
05/15/2012 9:09 AM
Hi......I want to buy an air compressor. What's the minimum capacity required for spray painting and operating air powered tools?
Anonymous Poster (1); crm (3); Gary (1); MarkhamCornoit (1); nvmani (2)
