Giannis writes:
I study mechanical engineering and I am designing a heat exchanger. Its duty is to recover heat from a power plant gases. I have designed it without fins and now I'm trying to add fins on the tubes outside surface. I am using this equation:
1/UAo=(1/ho*n*Ao)+Rw+Rf+(1/hi*Ai)
but I can't find reliable equations to determine Reynolds and Nusselt numbers, so I can determine ho. Those numbers in the case without fins are 280000 and 1300. The Reynolds numbers are very big and I can't find a solution with graphic method from experiments.
If somebody can help I will very much appreciate it!!!!
