Previous in Forum: ASTM d 1816   Next in Forum: Power Supply?
13 comments
LCR
01/08/2008 8:34 AM
Hello, I am new here and new user with devices like LCR.
Here is my question:
I want to put AC Voltage 2 Vpp (sinusoidal) with 50 kHz frequency in a circuit for a few minutes. In my lab there isn't an AC voltage source or function generator. There are LCR meter, Lock-in Amplifier and AC/DC current source.
I read the manuals and I didn't understand if I can exploit these devices and avoid to buy a new apparatus like function generator. I believe if any of the above could do my job is LCR (4284A Agilent). For Lock-In Amplifier I understand that it can't go up to 50 kHz, it's good for low signals and it also needs input signal to operate. For AC/DC current source I have to put parallel a big Ohmic Resistor but it's a cursory solution.
Can anyone give me some help? Is it the best solution to buy a function generator?
A lot of thanks!!!
Pathfinder Tags: LCR
Re: LCR
01/08/2008 2:15 PM
It all depends on what you are trying to do...
Let us know why you want to put in this signal and into what then maybe we can suggest a solution?
John.
Re: LCR
01/08/2008 3:36 PM
It's a simple circuit. We have the AC voltage source, a big ohmic resistor of 1 GΩ in series and a gap. Then I will put a specimen in the gap also in series which will have smaller resistance of some MΩ. The characteristics of the AC signal is as I wrote above. When the sample is stacked in the gap and the loop is closed, then all the voltage will drop in the big R, so I will know with this method that the electrical loop is closed.
You can not use DC voltage because the specimen will stick only in one electrode.
Re: LCR
01/08/2008 3:49 PM
I'd build a Wien bridge oscillator, plenty of circuits on the web....
Re: LCR
01/08/2008 4:05 PM
why a wien bridge oscillator? What I will gain from this?
Re: LCR
01/08/2008 5:32 PM
??? If you build one it will provide the the 50khz 2v p to p signal you wanted !!!
It will be quick simple and cheap to build....
Re: LCR
01/08/2008 6:06 PM
I searched in the internet for the Wien Bridge Oscillator. It's really interesting how simple it is... but as I found it's only for low frequencies (I saw an application with 20 kHz frequency). In higher frequencies there is a distortion. So I need something more stable, and controllable. If I am wrong, please correct me as I am not expert but amateur ... but thank you a lot for the answers.
Re: LCR
01/09/2008 3:07 AM
They usually go upto 20kh.... 'cos that's the top of the audio band... I don't think there would be much trouble taking it up to 50khz. The amplitude stability can be troublesome, they often use a small filament bulb or thermistor in the feedback loop.
I built one years ago..I think it only used 2 or 3 transistors... worked fine. Dunno where it is now...
It's a nice useful project for an amateur.
Re: LCR
01/09/2008 3:53 AM
I know this is the wimps way out but you end up with something which will be useful in the future. Cost your time accurately.
http://search.ebay.co.uk/search/search.dll?from=R40&_trksid=m37&satitle=function+generator
Re: LCR
01/09/2008 4:15 AM
so I suppose you suggest function generator than the other devices...
Thanks
Good Answers: 247
Re: LCR
01/09/2008 2:25 PM
This is not my field, but I've used 555 timers for this kind of thing. Others could better tell you if you can get close enough to a true sine wave (via filtering caps/inductor) for your purposes. They are so cheap and plentiful, that just playing around might be time well spent. Check the input and output sides of your resistor with a scope, and see if you're getting what you want. Part of having a lab is getting to play around, true?
However, if I had the budget to buy a function generator, I would jump at the chance, especially in a lab setting.
Re: LCR
01/09/2008 5:27 PM
Thank you for the answer...
I can not exactly play around in my lab... my supervisor wants some answers from me if we can use the above devices or we have to buy a new one...
Re: LCR
01/09/2008 11:39 PM
Hi Brintakis,
The 4284A should be able to provide the 2V p-p at 50kHz. Read the performance test section to find out which BNC it will come from. I think it's the current low, but not being at work I can't look at it now, and am not sure. If you want the voltage to be accurate, you will have to measure it with a scope or meter. There is a particular accessory made to check the output voltage that has one BNC output. That would be handy, but not essential. It sounds as though you need some more equipment in your lab. Good luck!
Regards,
S
Re: LCR
12/26/2009 8:11 AM
Hello,
Pls check there is provision in LCR meter it self to vary the AC V in rms volts. convert equivilent value required for 2vPP and you can apply it across the DUT (Device Under test)
get back to me if you have any difficulty on bgkmurthy@gmail.com
KM
Register to Reply 13 comments
bgkmurthy (1); Blink (1); Brintakis (5); Electroman (1); Randall (1); StandardsGuy (1); user-deleted-1105 (3)
