Previous in Forum: Remote Controlled Wireless Gas Valve   Next in Forum: Controlling the Process
For pick and place the sheet
01/08/2008 11:47 PM
For pick and place the sheet which method is best either vacuum or electromagnetic or anything else how i get the technical information related to it near by my place (chennai, tamilnadu, india)
Good Answers: 230
Re: For pick and place the sheet
01/09/2008 3:26 AM
Hello karthick
Please advise what sort of sheet you are "picking and placing".
  1. Cotton (Bedsheets - See, you need to specify please)
  2. Steel
  3. Stainless steel
  4. Glass
  5. Plastic
  6. Other (specify)
Also advise weight per sheet of the material, and the size/s you intend to use.
Depending on what you are doing, many automated machines just require pallets of sheets placed onto a loading tray, and they automatically are lifted and moved, for punching, drilling, gas/plasma cutting and so on.
Kind Regards....Reply with........
01/22/2008 2:32 AM
Hi
Welcome & thanks for ur interest.
It is CR & HR steel sheets
1250*400*3 may be the max size of sheets
weight max. of 11.8 kg
This arrangement for press operation.
for cutting and forming tool job loading
Best Regards
Thank you
Good Answers: 230
02/14/2008 6:37 PM
Sorry it's taken a while to reply, karthick
I would be using the vacuum cup pickup system.
It does not scratch or damage the sheeting.
For your nearest supplier try in Google: vacuum pickup steel sheet india
Advise your progress/lack of it, here thanks.
Kind Regards....
Register to Reply 3 comments
