Previous in Forum: Material of construction for Sulphuric acid storage tank.   Next in Forum: MSDS
Oxidation of Heat Transfer Fluid
01/09/2008 7:52 AM
Hi all - quick question regarding oxidation of heat transfer fluid in a test stand. I am using a heat transfer fluid designed for use in cooling and heating applications. It is composed of lighter hydrocarbons - very clear and water like in appearance (and smelly). I've been told it's composition is straight chain hydrocarbons, primarily c18 to c20 range with no benzene or halogens. The fluid is being used at the upper end of it's temperature range, ~170C. The fluid is oxidizing (I believe), the lightest hydrocarbons are boiling off, and I am getting a powdery (when dried), tan-coloured precipitate building up on the sintered bronze filters. Can anyone hazard a guess as to what the precipitate may be? Chemistry is definitely not my strong suit, so any help is appreciated. The next step with this rig will be to try a nitrogen blanket to prevent oxidation, but in the mean time I need to know what I'm cleaning up!
Thanks for your help, AndyC.
Re: Oxidation of Heat Transfer Fluid
01/09/2008 11:20 PM
Many commercial, thermal fluids have additives and impurities that would condense out as a solid. Hard to say what it would be. Best to have a sample tested; most labs would charge you fifteen hundred bucks (or more cause' you're in Oakville) but at least you would know for sure.
01/10/2008 8:29 AM
I would send the oil to Wearcheck for testing. I beleive they are in Ontario.
I would recommend the use of a better fluid. I sell a product that has a temperature limit of almost twice the 170 C. At the low temperature you are describing, my fluid should last 3-5 years before needing replacement.
Do you have filters in the system? They are very important. Your goal should be to reduce the micron rating to at least 10.
Prior to using your current fluid, did you clean the system?
The nitrogen blanket will help considerably.
Please e-mail me if you are interested in my product @ lubricants@rgreenwald.com
THEOILGUY55
Good Answers: 150
01/10/2008 9:41 AM
Instead of N2, you might want to consider Argon as your shielding gas. It is heavier than air and will not tend to be displaced or diluted as easily as N2.
You also might want to give these guys a call. They have a number of products that would be better fit for this application.
http://www.paratherm.com/heat_transfer_fluids.asp
Who is John Galt?
Register to Reply 3 comments
Anonymous Poster (1); Rorschach (1); THEOILGUY55 (1)
