Previous in Forum: plasma coatings   Next in Forum: erosion resistant coating
coating
01/11/2008 5:21 AM
can you suggest any material or coating which is refractory in nature and having excellenent erosion resistence against liquid melt of 1400 deg. centigrade.the coating shall give a min. delta T of 300 deg.centigrade?
Re: coating
01/11/2008 6:11 AM
It looks like a ceramic of some sort will withstand this.
Or how about firebrick?
Re: coating
01/15/2008 11:44 AM
fire brick erosion very fast
Good Answers: 143
Re: coating
01/11/2008 8:31 AM
Follow PW's hint and look into flamespraying ceramics.
Re: coating
01/15/2008 11:51 AM
TRIED WITH ZIRCON COAT-300 MICRON THICK .ITS NOT GIVING DESIRED DELTA T-OF MIN.300 DEG.CENTIGRADE.
Re: coating
01/11/2008 1:19 PM
We really need to know what the melted material is, what the base container is, and what temperature cycling is present. The refractory must be chemically resistant to the melt and strong enough to withstand thermal cycling (and exposure to the vapor above the melt)
Keith E Bowers, PMP
Re: coating
01/15/2008 11:48 AM
melted material is cast iron /steel melt,base container is m.s,the liqid melt shall be in contact for 2-3 min in each cycle.there shall be 6cycles per hour. should give min delta T OF 300 DEG.CENTIGRADE.
Register to Reply 6 comments
centricoats (3); Keith E Bowers (1); PWSlack (1); TVP45 (1)
