Previous in Forum: Bi-directional oil filter for natural gas   Next in Forum: my ?
Determining Conveyor Dead Weight
01/11/2008 9:50 AM
I'm trying to determine how to assume the total dry weight of a conveyor. Any thoughts?
Good Answers: 40
Re: Determining Conveyor Dead Weight
01/11/2008 9:58 AM
The original shipping documents from the manufacturer should have its weight listed.
01/11/2008 10:30 AM
Dead weight of the conveyor, or dry weight of the product the conveyor conveys?
Good Answers: 183
01/12/2008 7:13 AM
Do you want to determine the deadweight value for a correct tension of the conveyor?
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
01/12/2008 9:23 AM
As you said any thoughts -- these are ones. I couldn't get what you need certainly as well what's presumed under "dry"? (1) If there been meant mass(weight) of conveyor device a whole. Ok! there are two ways. (i) look at docs and find out. (ii) if any docs were lost you should to calculate and/or measure all main construction members (I suppose steel) and then you can sum a all its masses. (2) if you mean to find weight of bulk material which is conveyed by conveyor you can: (i) to install there a belt scale device or and look at what its show you. (ii) as well you can estimate flowrate using expression Q=3.6qvT, where Q --- how much of "dry"/"wet" material has passed through conveyor; q - span loading of material [kg/metre or pnd/ft]; v- conveyor belt speed; T- time in hours. For assessment a unknown q=Sxp, where S - material transverse cut square [ metres^2;], p- material density (bulk).
caramba (1); nick name (1); phoenix911 (1); techno (1)
You might be interested in: Conveyor Controls and Monitors, Conveyor Rollers
