Previous in Forum: Radiopaque Coating on Cateheters   Next in Forum: chemical engineer vs industrial management
how high tds water to be evaporate?
01/12/2008 8:00 AM
"how high tds water to be distraiod/ evaporate?"
Re: how high tds water to be evaporate?
01/14/2008 3:46 AM
Seawater is 35000-ish ppm TDS, depending on location. It works fine.
Good Answers: 101
01/14/2008 5:27 AM
Using an evaporator or allowing in to evaporate away naturally in a shallow basin.
