Previous in Forum: What are Thrust Load, Axial Load and Radial Load?   Next in Forum: Can Cast Iron Diaphragm Valves Be Used in Aseptic Applications?
Strength of 316 cold rolled SS
01/14/2008 9:28 AM
By what amount is the mechanical strength of 316 cold rolled SS reduced if it is heated to 650 deg. F and where did you get your information from?
Re: Strength of 316 cold rolled SS
01/14/2008 12:08 PM
Is this the loading temperature or is this a heat that will be introduced and removed frequently? There may be several ways this effects the material. Perhaps explain in what manner this is taking place or apllicable.
Good Answers: 58
01/14/2008 11:36 PM
The yield strength of 316 at 650 degrees f is 21 ksi. This information comes from 9.49 of High-Temperature Property Data: Ferrous Alloys published by ASM International ISBN: 0-87170-243-6
01/14/2008 11:57 PM
Thanks for the info. How does that number compare to the yield strength at ambient temperature?
Good Answers: 58
01/15/2008 7:56 AM
Temp(deg.f) Yield (ksi)
205-----------35
315-----------31
425-----------28
540-----------24
650-----------21
760---------- 18
870---------- 16
01/15/2008 4:38 AM
From ASME code, Section II, Part D:
The allowable tensile strength (to be used in design equations) for plate material SA240-316 (UNS No. : S31600) is : @ ambient temp.: 20 000 psi and @ 650 oF 16 600 psi.
01/15/2008 6:12 AM
By 50%( from 20>3500 C) Steel grade 1X189H T=SS AISI316
PP 115 E.I. Kazantsev: Industrial Furnaces :2nd Edition :Publishing House Metallurgia ,Moscow '77
Register to Reply 6 comments
Abdel Halim Galala (1); Anonymous Poster (1); joltnjny (1); MUKULMAHANT (1); welderman (2)
