Previous in Forum: Making Stainless Steel Vacuum Flasks   Next in Forum: Fighting for Efficiency
Rule of Thumb for Remaining Wall Thickness on Threaded Insert Repair
01/14/2008 10:04 AM
In the aviation industry, we're heavily regulated by OEM & Federal "Acceptable Methods, Techniques and Practices". As such, I'd be interested in your input on the following hypothetical repair:
Problem: Pulled Threads in Aluminum Housing (2024-T4)
Proposed Repair: Threaded Insert (Heli-Coil)
Repair Dimensions: Remaining wall thickness after tapping for Heli-Coil = 0.070".
Per the OEM standard practice governing maintenance on this unit, the proposed repair would be considered unacceptable since the remaining wall thickness would fall below the 0.090" min requirement. Based on experience in your respective industries, would you be able to proceed with this repair?
Thanks in advance for your input.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Rule of Thumb for Remaining Wall Thickness on Threaded Insert Repair
01/15/2008 2:38 AM
Hi,
In all industries we all have some types of regulations, standards, etc. to follow.
It is supposed that people who issued the requirements took into account all the design considerations (including "safety factors").
So, if you try to change any limitation, you must know all considerations the designers had in mind and evaluate the decission at your own risk.
In other words, I only would change a requirement if I know perfectly all design conditions (ambient, load cases, etc) and after the corresponding evaluation.
My recommendation: Don't accept that repair.
01/15/2008 5:09 AM
Per code OEM & Federal "Acceptance Methods, Techniques and Practices", this repair is not accepted.
Otherwise, you can proceed a stress analysis to find the stresses through that part of reduced wall thickness, and compared with the accepted stress figures.
01/15/2008 9:14 AM
To ask another way, what "rule of thumb" exists in other industries use for remaining wall thickness? The standard we generally work to falls between 0.070"-0.090". I was just curious as to what "standards" others may be using. (More of a general question)
Thanks for the input.
01/15/2008 12:05 PM
You would have to have the OEM/PMA manufacturer review the proposed repair, do whatever analysis THEY require in order to accept the proposed repair. YOU can legally ONLY conform to the presently acceptable repair tolerances. Any deviation MUST be sanctioned in writing by the OEM/PMA manufacturer.
Keith E Bowers, PMP
Good Answers: 16
01/16/2008 7:11 PM
I have dealt with cases where the wall thickness for a thread was inadequate by adding additional weld metal to outside of a flange to a metallurgist's requirements. This was followed by a full heat treatment. Is this the sort of information you are interested in?
Make it so.
01/17/2008 5:19 PM
There are many way to repair thread. Helicoil is only one. There are other kind of inserts. You can drill it out and weld a solid piece in then tap it again. You can epoxy the hole then tap it. You can drill the whole thing out and replace with thread rivet or PEM insert.
Rule of thumb: If you got a bad feeling about it, don't do it.
Pineapple
06/16/2023 10:00 AM
<...unacceptable...> to whom?
That is the direction of travel for these sorts of questions, for that is where the liability lays.
Register to Reply 7 comments
Abdel Halim Galala (1); BlueAussieBoy (1); Jetmxmanager (1); Keith E Bowers (1); Kwetz (1); Pineapple (1); PWSlack (1)
